Old 10-07-2007, 06:40 PM   #1 (permalink)
ayushman9's Avatar
Unhappy Which UNLIMITED Broadband To use?
I have a bsnl RS 250 - 2mbps - 1 GB ,but despite this my monthly Bill goes over Rs 2k (only net) and then also my my demand are not met (That is THEIR ARE LOTS OF STUFF TO BE DOWNLOADED) .And to top it My father is threatening me to cut the net connection if i don't call up my habit . However he has given me the chance to change the connection but under Rs 0.7 to 0.8k
I want to know what plans are present for unlimited broadband .Though I Prefer high speed but if budget is constraint i can also prefer 128 to 256 mpbs . AND YES I CAN KEEP MY PC ON FOR WHOLE NIGHT FOR BIG DOWNLOADS( <1 GB) TO FINISH . please can you suggest me which service to go .My uncle is saying Airtel offers the best in price for unlimited broadband?
ayushman9 is offline
Old 10-07-2007, 06:44 PM   #2 (permalink)
Smile Re: Which UNLIMITED Broadband To use?
go for a unlimited plan .it will cost 900/month it has a speed of 256 kbps.
mastery20 is offline
Old 10-07-2007, 06:46 PM   #3 (permalink)
On the net
arnab2kool's Avatar
Default Re: Which UNLIMITED Broadband To use?
M8 I am using BSNL Broadband Home 500 for since 1 year. Why dont u opt for this plan it gives 2.5 GB limit. And if you want to pick up Unlimited then you can choose Unlimited plans provided from BSNL. You can find the details from the nearest branch.
Thank you.
YOUTHS are not USELESS
YOUTHS are USED LESS
CORE 2 DUO USER
arnab2kool is offline
Old 10-07-2007, 07:10 PM   #4 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Now,I'd say BSNL UL plan for 900 bucks.It gives you a 256 kbps pipe. Else, opt for their 500 bucks plan which is UL at night.... Now its upto 2 mbps. So, on a good day, you can d/l a lot. BTW, what do you d/l ?
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 10-07-2007, 07:23 PM   #5 (permalink)
Go for plans that allow night-time unlimited, as they are likely to be cheaper. For example, in Airtel, I can get for around 600 Night Unlimited (as addon) with about 500 MB download daytime (I think)...
Arun
sakumar79 is offline
Old 10-07-2007, 07:52 PM   #6 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
go for tata broadband 256 kbps
bhushan05d251 is offline
Old 10-07-2007, 08:28 PM   #7 (permalink)
1337 |)00|) \m/
Tata's service is good too.
Old 10-07-2007, 08:47 PM   #8 (permalink)
ayushman9's Avatar
well i do think you know what i d/l . I can say i am a T.O.R.R.E.N.T worshipper (not a devoted one,you see rapidshr is more reliable).
I think it is better i opt for day and night unlimited .Atleast it will limit my budjet to a figure ?
And yes i personally don/t approve of BSNL .They have a habit of making the applicant run around several times . I t is better to opt for a private player.
Old 12-07-2007, 10:01 AM   #9 (permalink)
Hell Sucks!!!
I think you need to go in for Night UL connection specially whn u say that u r a Torrent Worshipper
coz then u'll b abl to download more in whole night than leaving ur PC running 24x7
As for daytime, the limit, 1GB is mesely bt quite okay for normal surfing as ur dwnlds wl nw b scheduled for nights !
ashu_dps is offline
Old 12-07-2007, 03:54 PM   #10 (permalink)
g_goyal2000's Avatar
MTNL Triband 256 KBPS
TriB 590NU (Rs. 590): Night unlimited (12:00 am to 8 am) + 1 GB monthly limit free only for daytime (8 am to 12 am).
1 GB download is for entire month, not daily 1 GB.
DSL 949 (Rs. 949): Unlimited
If u'r own router, then no rental. If MTNL's, then Rs. 50/- per month router rental.
http://delhi.mtnl.net.in/commercial/...and_tariff.htm
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 12-07-2007, 08:15 PM   #11 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
BSNL Broadband plan costs me rs 720 PM coz rs 180 rental is included in the 900 Plan so in actual it costs rs 780 , and i get speeds >30KBps constantly
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 12-07-2007, 09:47 PM   #12 (permalink)
sify 128 unlimited ....791.........
sify 256 unlimited..... 1122.......
at least i have good exp
u can download what ever u want...p2p is not blocked at all.....
first try to find out whether its available in u r area and hows service..
i m happy since 1 yr...with sify
mkmkmk is offline
Old 12-07-2007, 11:00 PM   #13 (permalink)
Help~Is~Here's Avatar
Sify Suc*s, royall does. Never go for it!! It's not the same everywhere! Majority say it is uselss!!
I would suggest you go for the BSNL Home 500 plan. Because you have about 2.5GB usage and night unlimited where between 2am and 8am, you can download appox ~2-3GB of data. And it's only Rs500/month. So, if you can stick to night downloading, then take this one. Or you can go for the Home900UL. But that's got much lesser speed. You can download whatever you download in a day with that connection in just 6 hours in the night on a 2Mbps line. So, you do the math.
I would certainly recommend BSNL although intial hassles can be there, it's the most reliable service. There are lot of private players who promise you a lot of SLA's but none are met majority of the times, for eg. Airtel's 24hour gauranteed fix which never happens.
Which ever ISP you choose, the bottom lines have been put in place by the TRI. TRI has given a maximum of 48hrs repair and if it doesn't work within that time, you will get additional days free for the no. of days it hasn't worked. So, regardless of which ISP you select, the service standards are going to be the same.
Last edited by Help~Is~Here; 12-07-2007 at 11:02 PM. Reason: Automerged Doublepost
Help~Is~Here is offline
Old 12-07-2007, 11:03 PM   #14 (permalink)
Wire muncher!
infra_red_dude's Avatar
yeah and if u pay rs.9000 as one time payment for an year then the cost per month appreiciably reduces!
infra_red_dude is offline
Old 13-07-2007, 12:39 AM   #15 (permalink)
+1 for BSNL 900 UL plan
kooabs03 is offline
Old 13-07-2007, 08:47 AM   #16 (permalink)
bsnl rocks
desi-tek.org is offline
Old 13-07-2007, 09:03 AM   #17 (permalink)
Is bsnl available in delhi as mtnl?
ranjan2001 is offline
Old 13-07-2007, 12:49 PM   #18 (permalink)
 Macboy
goobimama's Avatar
Instead of going for the home500 plan, i opted for home1000 where I get 5GB per month. So at least I can surf in peace...
I'm like a bird... :)
goobimama is offline
Old 13-07-2007, 02:38 PM   #19 (permalink)
Yes, MTNL is the BSNL in Delhi.
Old 13-07-2007, 03:01 PM   #20 (permalink)
NO its the other way round , if you confirm it to be so.
BSNL is MNTL in delhi.
Old 13-07-2007, 03:07 PM   #21 (permalink)
Dude, either ways, it's the same. But, I'll confirm it.
BSNL is the main company and it's available all over the country but BSNL has been denied access in the capital for some absurd reason. Hence, MTNL works as a subsidary of BSNL in Delhi. So, BSNL still makes money from Delhi.
Old 13-07-2007, 06:43 PM   #22 (permalink)
a_tif's Avatar
there is no bsnl in mumbai n delhi
only mtnl
mtnl has diff plans at diff rates
mtnl mumbai has introduced 849NU plan
speed of 2Mbps
1.25 gb during day
unlimited during night 12-8 am
but thats 4 mtnl mumbai only not delhi
a_tif is offline
Old 14-07-2007, 12:11 AM   #23 (permalink)
BSNL & MTNL are not the same.
MTNL is only in Delhi & Mumbai.
BSNL is in rest of India.
BSNL is also in some parts of Mumbai.
Since they're both owned by the government & because of which they offer almost same plans & tariffs, they're often mistaken to be one. But they're not.
Old 15-07-2007, 12:46 PM   #24 (permalink)
I suggest you get some cash arranged from your near and dears and friends and take airtel broadband...In delhi it offers, awesome speeds and service..dont know about you area...
You can have 699 plan for 128 kbps unlimited in daytime and night time it is doubled. In 999 plan 256 kbps at daytime and at night it is doubled...These are combo plans, meant to be taken with the phone line.
In 999 plan they are offering Re. 1 per 3 minutes of call flat to anywhere ie local
Abhishek Bhattacharya
abhishek_del is offline
Old 18-07-2007, 01:31 PM   #25 (permalink)
airtel has changed its plans & tariffs for broadband. it's no longer offering double speed plan for new users.
Old 25-05-2008, 08:16 PM   #26 (permalink)
TriB 749NU (Rs. 749) @ 2 MBPS: Night unlimited (12:00 am to 8 am) + 1.25 GB monthly limit free only for daytime (8 am to 12 am).
1.25 GB download is for entire month, not daily 1.25 GB.
TriB 799 (Rs. 799) @ 256 KBPS: Unlimited
Old 25-05-2008, 08:26 PM   #27 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
*sigh again* i know this is interesting and all, but nearly 1 yr old thread mate...
dheeraj_kumar is offline
Broadband in Windows V/S Broadband in Linux.. Manshahia Open Source 3 30-05-2007 08:27 PM
BSNL launches Tariffs for Unlimited Broadband Business Plans gary4gar Random News 3 03-04-2007 01:35 AM
BSNL launches Tariffs for Unlimited Broadband Business Plans int86 Technology News 1 25-03-2007 06:53 PM
Real Unlimited Browsing for Broadband users piyushp_20 Broadband and DTH 9 06-01-2007 01:44 PM
- by Niilesh
