Old 07-07-2007, 12:44 PM   #1 (permalink)
Default start up problem in winxp
Please help!!!!
I use Winxp Pro sp2.After the log on screen my PC takes a minimum of 10mins to load.Facing the problem from 2days.After loading everythings fine>
there is some system file corrupted.How to find the file & repair the same>
sudheer17682 is offline
Old 07-07-2007, 03:07 PM   #2 (permalink)
Default Re: start up problem in winxp
dude try this copy/paste the following code in notepad and the save it as .REG
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters]
"EnablePrefetcher"=dword:00000002
Finally double clcik on it and then click on Yes ,restart n then c da changes
Hope this helps
iceeeeman is offline
Old 07-07-2007, 03:16 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
make you win Xp super fast:
MASTER TUTORIAL: Make Your Windows XP Super Fast !!!
MAKE WINXP STARTUP/SHUTDOWN FASTER !
ravi_9793 is offline
Old 08-07-2007, 01:55 PM   #4 (permalink)
Booting Nicotine!!
spironox's Avatar
how about xpsmoker ! i used that and now the pc is blazing fast ..downside its a paid software ! ..ahemm
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 08-07-2007, 05:37 PM   #5 (permalink)
defrag ur hdd and repair your windows.
abhijangda is offline
Old 08-07-2007, 11:06 PM   #6 (permalink)
Is actually a real word..
Originally Posted by ravi_9793
yeah if you have looked at those and tried those solutions, and you're still facing problems, you maybe better off with a reinstall.
Liggy is offline
Old 08-07-2007, 11:08 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
c above-mentioned threads.
but if u ask me one imp thing : reduce ur startups and check for malware infections (thats 2 actually )
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 08-07-2007, 11:20 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
yes.........first step n most important one
Old 10-07-2007, 09:48 AM   #9 (permalink)
Boom Boom Boom
cooldudie3's Avatar
u can get a guy to fix ur problem( i mean a proffessional) i can really help
cooldudie3 is offline
start up problem ritish Software Q&A 10 27-03-2007 10:24 PM
start up problem on win xp pro sp 2 psnegi26136 Software Q&A 6 22-02-2007 01:58 PM
Problem with windows XP-Start-Run tkprakash Software Q&A 2 29-09-2005 05:56 PM
Start Page Problem with IE... Choto Cheeta QnA (read only) 25 29-09-2005 01:51 PM
Windows Start Problem sid_b6505 Software Q&A 5 17-08-2005 04:11 PM
- by Niilesh
