Old 05-07-2007, 11:35 PM   #1 (permalink)
kool's Avatar
Thumbs down ♪♪♪♪ Problem with VTP7, Setup Program doesn't even starts..
My problem is vvvvv simple
It's just I can not even start the setup of VTP. Every time I double click on VTP7 SETUP icon, simply nothing happenes nad no SETUP starts I downloaded the file from several places but the same results. Even i formatted my hard disk and re-installed XP, but same prob. Why i'm unable2install VTP7 ??????
The setup Program don't even appear as if i did nothing.
PS. Though I've tried the same file in another PC b4 I take it home and it worked!
►► ◄◄ :smile::smile:
kool is offline
Old 05-07-2007, 11:50 PM   #2 (permalink)
Is actually a real word..
Default Re: ♪♪♪♪ Problem with VTP7, Setup Program doesn't even starts..
hmmm try what these guys suggest safemode and deleteing an update. (damn dirty Windows updates!) http://www.windowsxlive.net/?p=1138
Liggy is offline
Old 06-07-2007, 05:13 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
^^ Actually even if u DON'T REMOVE that update, still it works !!! (at least for ME)
I think his problem is something different !
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 06-07-2007, 07:47 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Have you tried re downloading the VTP installation files ...? Maybe those are corrupt ..
From IE7 onwards, Windows verify the content of executable files which are downloaded from internet before running them which may cause some delay in execution ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 07-07-2007, 04:48 PM   #5 (permalink)
morpheusv6's Avatar
Worked fine on my system. Downloaded the zip file through torrents and am seeding it still.
Deven
morpheusv6 is offline
♫ ♫altec Lansing Atp 3 ♫♫ ♪☺♪ hermit Networking 18 27-08-2006 11:06 AM
setup problem kjuvale QnA (read only) 5 11-09-2005 11:15 PM
XP setup problem chanduthebest Software Q&A 3 03-07-2005 01:46 PM
Starting a program as soon as winows starts..... abhi_shake Software Q&A 2 03-04-2005 11:57 AM
Program should load when windows98 starts and should stay eruvungaren Software Q&A 2 10-12-2004 05:18 PM
- by Niilesh
