Old 04-07-2007, 09:15 PM   #1 (permalink)
ajaybc's Avatar
Exclamation Help me use utorrent
I have a BSNL broadband connection which uses UTStar ADSL 2+ modem/Router.Recently in utorrent I noticed a small caution icon and when I mouse hover over it it says no connections and suggests to change network settings.Because of this my download rates also are suffering.Please help me.
ajaybc is offline
Old 04-07-2007, 10:30 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Help me use utorrent
Search Forums:
Torrenting For Dummies
Guide to Bittorrent
KDE on ArchLinux
The Unknown is offline
Old 05-07-2007, 12:04 AM   #3 (permalink)
UbuntuUser
cynosure's Avatar
Try switching on DHT. This will help you get more connections (Seeders + leechers)
And that caution icon is displayed when your port is not forwarded properly. Try enteringf any random number (4 digits atleast) and check whether it is forwarded or not.
cynosure is offline
Old 05-07-2007, 12:34 AM   #4 (permalink)
prasad_den's Avatar
Go to
http://www.portforward.com/english/r...outerindex.htm
Select your router...
Next click on the application for which you need to forward the ports in the page that opens (utorrent in your case)
Follow all the instructions..
prasad_den is offline
Old 19-07-2007, 07:44 AM   #5 (permalink)
ajaybc's Avatar
Question Re: Help me use utorrent
Thank u Prasad. My router is shown there and I tried to do whatevr they told me.
But their router config interface is very different from mine.Mine has got no portforwarding in advanced options.
I even searched for firmware upgrades but even that is not available.Damn that BSNL and UT star goes to hell!!!!!
Please suggest any other way if there is any
ajaybc is offline
Old 19-07-2007, 08:53 AM   #6 (permalink)
prasad_den's Avatar
^^ Can you post a screenshot or a list of all the options available in your router config page..?
Old 19-07-2007, 07:44 PM   #7 (permalink)
ajaybc's Avatar
This was the page I got when I clicked advanced in the configuration.
ajaybc is offline
LINUX - DVD and utorrent srimaya_rath Open Source 3 08-01-2007 08:37 AM
utorrent trouble forever Software Q&A 5 25-12-2006 02:51 PM
Utorrent wizrulz QnA (read only) 2 20-12-2006 10:16 PM
What is this in utorrent ? manas QnA (read only) 2 26-11-2006 12:12 PM
Utorrent gau_pppu Software Q&A 5 17-11-2006 06:44 PM
- by Niilesh
