# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_FLT_DIVIDE_BY_ZERO (0xc000008e) at pc=0x015ccfdf, pid=2400, tid=2992
# Java VM: Java HotSpot(TM) Client VM (1.6.0_01-b06 mixed mode, sharing)
# Problematic frame:
# j java.text.DecimalFormat.format(DLjava/lang/StringBuffer;Ljava/text/Format$FieldDelegate
Ljava/lang/StringBuffer;+8
# If you would like to submit a bug report, please visit:
http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x00da6400): JavaThread "main" [_thread_in_Java, id=2992]
siginfo: ExceptionCode=0xc000008e, ExceptionInformation=0x00000000
Registers:
EAX=0x00000000, EBX=0x0000006f, ECX=0x20000002, EDX=0x00000000
ESP=0x00221048, EBP=0x00221070, ESI=0x2ac4371c, EDI=0x002210a4
EIP=0x015ccfdf, EFLAGS=0x00010246
Top of Stack: (sp=0x00221048)
0x00221048: 00000000 3ff00000 00221050 2ac436d8
0x00221058: 002210a4 2b5fb3c8 00000000 2b5fc7f8
0x00221068: 00000000 00221094 002210c8 015c2dd7
0x00221078: 00000000 00000000 00000000 00000000
0x00221088: 00000000 00000000 00000000 1f760f18
0x00221098: 1e9d4f88 00000000 00000000 1e9d4bd0
0x002210a8: 002210a8 2ac439ec 002210e0 2b5fb3c8
0x002210b8: 00000000 2b5fc898 00221094 002210d0
Instructions: (pc=0x015ccfdf)
0x015ccfcf: e7 9d 6d dc 0c 24 de f1 db 2d 34 e7 9d 6d de c9
0x015ccfdf: dd 1c 24 dd 04 24 58 5a 0f b6 5e 01 46 ff 24 9d
Stack: [0x00030000,0x00230000), sp=0x00221048, free space=1988k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j java.text.DecimalFormat.format(DLjava/lang/StringBuffer;Ljava/text/FieldPosition
Ljava/lang/StringBuffer;+20
j java.text.NumberFormat.format(D)Ljava/lang/String;+12
j org.gudy.azureus2.core3.util.DisplayFormatters.for matDecimal(DIZZ)Ljava/lang/String;+167
j org.gudy.azureus2.core3.util.DisplayFormatters.for matByteCountToKiBEtc(JZZ)Ljava/lang/String;+74
j org.gudy.azureus2.core3.util.DisplayFormatters.for matByteCountToKiBEtc(J)Ljava/lang/String;+3
j org.gudy.azureus2.ui.swt.views.tableitems.mytorren ts.DownItem.refresh(Lorg/gudy/azureus2/plugins/ui/tables/TableCell
V+52
j org.gudy.azureus2.ui.swt.views.table.impl.TableCol umnImpl.invokeCellRefreshListeners(Lorg/gudy/azureus2/ui/swt/views/table/TableCellCore
V+36
j org.gudy.azureus2.ui.swt.views.table.impl.TableCel lImpl.refresh(ZZZ)Z+413
j org.gudy.azureus2.ui.swt.views.table.impl.TableCel lImpl.refresh(ZZ)Z+7
j org.gudy.azureus2.ui.swt.views.table.impl.TableRow Impl.refresh(ZZ)Z+73
j org.gudy.azureus2.ui.swt.views.TableView.visibleRo wsChanged()V+283
j org.gudy.azureus2.ui.swt.views.TableView._addDataS ourcesToSWT([Ljava/lang/Object
V+762
j org.gudy.azureus2.ui.swt.views.TableView.access$28 00(Lorg/gudy/azureus2/ui/swt/views/TableView;[Ljava/lang/Object
V+2
j org.gudy.azureus2.ui.swt.views.TableView$30.runSup port()V+8
j org.gudy.azureus2.core3.util.AERunnable.run()V+1
j org.eclipse.swt.widgets.RunnableLock.run()V+11
j org.eclipse.swt.widgets.Synchronizer.runAsyncMessa ges(Z)Z+29
j org.eclipse.swt.widgets.Display.runAsyncMessages(Z )Z+5
j org.eclipse.swt.widgets.Display.readAndDispatch()Z +74
j org.gudy.azureus2.ui.swt.mainwindow.SWTThread.<ini t>(Lcom/aelitis/azureus/ui/IUIIntializer
V+186
j org.gudy.azureus2.ui.swt.mainwindow.SWTThread.crea teInstance(Lcom/aelitis/azureus/ui/IUIIntializer
V+34
j org.gudy.azureus2.ui.swt.mainwindow.Initializer.<i nit>(Lcom/aelitis/azureus/core/AzureusCore;Lorg/gudy/azureus2/ui/swt/StartServer;[Ljava/lang/String
V+76
j org.gudy.azureus2.ui.swt.Main.<init>([Ljava/lang/String
V+116
j org.gudy.azureus2.ui.swt.Main.main([Ljava/lang/String
V+5
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x04d18000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3160]
0x04d95000 JavaThread "AWT-Shutdown" [_thread_blocked, id=3420]
0x04d94400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3328]
0x04d4c400 JavaThread "Slidey" daemon [_thread_blocked, id=3740]
0x04da5c00 JavaThread "Process Data Sources[1]" daemon [_thread_blocked, id=3600]
0x04cc8000 JavaThread "Process Data Sources[1]" daemon [_thread_blocked, id=2756]
0x04cd6000 JavaThread "GUI updater" [_thread_blocked, id=3660]
0x04d12400 JavaThread "Timer
rocess Data Sources" daemon [_thread_blocked, id=3076]
0x04d13800 JavaThread "Timer
rocess Data Sources" daemon [_thread_blocked, id=2932]
0x04d17c00 JavaThread "Simple Timer[1]" daemon [_thread_blocked, id=3436]
0x04cda800 JavaThread "Rating::Initializer" daemon [_thread_blocked, id=3172]
0x04ce8c00 JavaThread "Timer:AggregatedList" daemon [_thread_blocked, id=3472]
0x04cfe800 JavaThread "AZInstanceManager:initialSearch" daemon [_thread_blocked, id=1736]
0x04cdbc00 JavaThread "MCGroup:CtrlListener" daemon [_thread_in_native, id=3564]
0x01024c00 JavaThread "MCGroup:MCListener" daemon [_thread_in_native, id=2712]
0x04cc5c00 JavaThread "StatsWriter" daemon [_thread_blocked, id=756]
0x04ccec00 JavaThread "MagnetPlugin:init" daemon [_thread_blocked, id=2720]
0x04ccc000 JavaThread "DHTTrackerPlugin:init" daemon [_thread_blocked, id=2648]
0x04cd2c00 JavaThread "DHTPlugin.init" daemon [_thread_in_native, id=3268]
0x04ccac00 JavaThread "Universal Plug and Play (UPnP)::SSDP:queryLoop" daemon [_thread_blocked, id=600]
0x04cc8c00 JavaThread "MCGroup:CtrlListener" daemon [_thread_in_native, id=1652]
0x04c88800 JavaThread "MCGroup:MCListener" daemon [_thread_in_native, id=1760]
0x04c69c00 JavaThread "Timer
lugin azlocaltracker:azlocalplugin:init" daemon [_thread_blocked, id=3468]
0x04cc4800 JavaThread "Timer
lugin azextseed:ExternalPeerInitialize" daemon [_thread_blocked, id=3572]
0x04cc3c00 JavaThread "MagnetURIHandler" daemon [_thread_in_native, id=3384]
0x04cba800 JavaThread "HostNameToIPResolver" daemon [_thread_blocked, id=3132]
0x04bf3c00 JavaThread "TRHost:ListenDispatcher" daemon [_thread_blocked, id=3348]
0x04bf0400 JavaThread "GM:ListenDispatcher" daemon [_thread_blocked, id=3480]
0x04c0b000 JavaThread "Global Status Checker" [_thread_blocked, id=3176]
0x04ca6800 JavaThread "TRHost::stats.loop" daemon [_thread_blocked, id=752]
0x04bd6c00 JavaThread "Tracker Scrape" daemon [_thread_blocked, id=2800]
0x04cc2c00 JavaThread "DM:ListenAggregatorDispatcher" daemon [_thread_blocked, id=2644]
0x04bf9400 JavaThread "FMFileManager::closeQueueDispatcher" daemon [_thread_blocked, id=2844]
0x04bce400 JavaThread "Start Server" daemon [_thread_in_native, id=1272]
0x04bb7000 JavaThread "NetworkGlueUDP" daemon [_thread_blocked, id=3332]
0x04bb6800 JavaThread "PRUDPPacketReciever:6881" daemon [_thread_in_native, id=2364]
0x04bc8c00 JavaThread "WriteController:WriteSelector" daemon [_thread_in_native, id=580]
0x04bcc000 JavaThread "ReadController:ReadSelector" daemon [_thread_in_native, id=3444]
0x04bbb400 JavaThread "VServerSelector
ort6881" daemon [_thread_in_native, id=3020]
0x04bbdc00 JavaThread "ConnectDisconnectManager" daemon [_thread_in_native, id=3800]
0x04761000 JavaThread "ReadController:ReadProcessor" daemon [_thread_blocked, id=2360]
0x04ba4c00 JavaThread "WriteController:WriteProcessor" daemon [_thread_blocked, id=2316]
0x04783000 JavaThread "Timer:VivaldiV2PositionProvider
ing" daemon [_thread_blocked, id=1732]
0x0478d000 JavaThread "AEThreadMonitor" daemon [_thread_blocked, id=412]
0x04764400 JavaThread "Timer:Simple Timer" daemon [_thread_blocked, id=1152]
0x04767800 JavaThread "SystemTime" daemon [_thread_blocked, id=3516]
0x0102d000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2100]
0x01028400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3148]
0x01027000 JavaThread "Attach Listener" daemon [_thread_blocked, id=2028]
0x01026400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3340]
0x0101e400 JavaThread "Finalizer" daemon [_thread_blocked, id=748]
0x0101d400 JavaThread "Reference Handler" daemon [_thread_blocked, id=928]
=>0x00da6400 JavaThread "main" [_thread_in_Java, id=2992]
Other Threads:
0x01014000 VMThread [id=3620]
0x0102f000 WatcherThread [id=3084]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 339K [0x1e990000, 0x1ea90000, 0x1f360000)
eden
[error occurred during error reporting, step 190, id 0xc000008e]
Dynamic libraries:
0x00400000 - 0x00431000 C:\Program Files\Azureus\Azureus.exe
0x7c900000 - 0x7c9b0000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f5000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.DLL
0x77e70000 - 0x77f01000 C:\WINDOWS\system32\RPCRT4.dll
0x77f10000 - 0x77f57000 C:\WINDOWS\system32\GDI32.dll
0x7e410000 - 0x7e4a0000 C:\WINDOWS\system32\USER32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\msvcrt.dll
0x7c9c0000 - 0x7d1d5000 C:\WINDOWS\system32\SHELL32.DLL
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
0x629c0000 - 0x629c9000 C:\WINDOWS\system32\LPK.DLL
0x74d90000 - 0x74dfb000 C:\WINDOWS\system32\USP10.dll
0x773d0000 - 0x774d3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
0x6d7c0000 - 0x6da07000 c:\program files\java\jre1.6.0_01\bin\client\jvm.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x7c340000 - 0x7c396000 C:\Program Files\Azureus\MSVCR71.dll
0x6d310000 - 0x6d318000 c:\program files\java\jre1.6.0_01\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d770000 - 0x6d77c000 c:\program files\java\jre1.6.0_01\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 c:\program files\java\jre1.6.0_01\bin\java.dll
0x6d7b0000 - 0x6d7bf000 c:\program files\java\jre1.6.0_01\bin\zip.dll
0x6d570000 - 0x6d583000 C:\Program Files\Java\jre1.6.0_01\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x10000000 - 0x1001d000 C:\WINDOWS\system32\avgfwafu.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\system32\mswsock.dll
0x662b0000 - 0x66308000 C:\WINDOWS\system32\hnetcfg.dll
0x71a90000 - 0x71a98000 C:\WINDOWS\System32\wshtcpip.dll
0x042c0000 - 0x042d2000 C:\Program Files\Azureus\aereg.dll
0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\uxtheme.dll
0x74720000 - 0x7476b000 C:\WINDOWS\system32\MSCTF.dll
0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime
0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll
0x6d750000 - 0x6d758000 C:\Program Files\Java\jre1.6.0_01\bin\sunmscapi.dll
0x77a80000 - 0x77b14000 C:\WINDOWS\system32\CRYPT32.dll
0x77b20000 - 0x77b32000 C:\WINDOWS\system32\MSASN1.dll
0x6d560000 - 0x6d569000 C:\Program Files\Java\jre1.6.0_01\bin\management.dll
0x6d590000 - 0x6d599000 C:\Program Files\Java\jre1.6.0_01\bin\nio.dll
0x0ffd0000 - 0x0fff8000 C:\WINDOWS\system32\rsaenh.dll
0x769c0000 - 0x76a73000 C:\WINDOWS\system32\USERENV.dll
0x5b860000 - 0x5b8b4000 C:\WINDOWS\system32\netapi32.dll
0x76d60000 - 0x76d79000 C:\WINDOWS\system32\iphlpapi.dll
0x76d40000 - 0x76d58000 C:\WINDOWS\system32\MPRAPI.dll
0x77cc0000 - 0x77cf2000 C:\WINDOWS\system32\ACTIVEDS.dll
0x76e10000 - 0x76e35000 C:\WINDOWS\system32\adsldpc.dll
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x76b20000 - 0x76b31000 C:\WINDOWS\system32\ATL.DLL
0x77120000 - 0x771ac000 C:\WINDOWS\system32\OLEAUT32.dll
0x76e80000 - 0x76e8e000 C:\WINDOWS\system32\rtutils.dll
0x71bf0000 - 0x71c03000 C:\WINDOWS\system32\SAMLIB.dll
0x77920000 - 0x77a13000 C:\WINDOWS\system32\SETUPAPI.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
0x065c0000 - 0x0660a000 C:\Program Files\Azureus\swt-win32-3318.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\comdlg32.dll
0x42c10000 - 0x42cdf000 C:\WINDOWS\system32\WININET.dll
0x06620000 - 0x06629000 C:\WINDOWS\system32\Normaliz.dll
0x42990000 - 0x429d5000 C:\WINDOWS\system32\iertutil.dll
0x74c80000 - 0x74cac000 C:\WINDOWS\system32\oleacc.dll
0x76080000 - 0x760e5000 C:\WINDOWS\system32\MSVCP60.dll
0x099c0000 - 0x09c85000 C:\WINDOWS\system32\xpsp2res.dll
0x76380000 - 0x76385000 C:\WINDOWS\system32\msimg32.dll
0x6d000000 - 0x6d1c3000 C:\Program Files\Java\jre1.6.0_01\bin\awt.dll
0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x73760000 - 0x737a9000 C:\WINDOWS\system32\ddraw.dll
0x73bc0000 - 0x73bc6000 C:\WINDOWS\system32\DCIMAN32.dll
0x77b40000 - 0x77b62000 C:\WINDOWS\system32\appHelp.dll
0x76fd0000 - 0x7704f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77050000 - 0x77115000 C:\WINDOWS\system32\COMRes.dll
0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
0x0b910000 - 0x0bb2d000 D:\OFFICE~1\Office12\GRA8E1~1.DLL
0x68ef0000 - 0x68fe1000 D:\OFFICE~1\Office12\GrooveUtil.DLL
0x78130000 - 0x781cb000 C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a 1e18e3b_8.0.50727.163_x-ww_681e29fb\MSVCR80.dll
0x68ff0000 - 0x68ff7000 D:\OFFICE~1\Office12\GrooveNew.DLL
0x7c630000 - 0x7c64b000 C:\WINDOWS\WinSxS\x86_Microsoft.VC80.ATL_1fc8b3b9a 1e18e3b_8.0.50727.42_x-ww_6e805841\ATL80.DLL
0x77a20000 - 0x77a74000 C:\WINDOWS\System32\cscui.dll
0x76600000 - 0x7661d000 C:\WINDOWS\System32\CSCDLL.dll
0x6d450000 - 0x6d474000 C:\Program Files\Java\jre1.6.0_01\bin\jpeg.dll
0x6d1f0000 - 0x6d21f000 C:\Program Files\Java\jre1.6.0_01\bin\cmm.dll
0x0b350000 - 0x0b363000 C:\Program Files\Azureus\swt-gdip-win32-3318.dll
0x4ec50000 - 0x4edf3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
0x0c240000 - 0x0c317000 C:\PROGRA~1\ALCOHO~1\ALCOHO~1\AxShlex.dll
0x5edd0000 - 0x5ede7000 C:\WINDOWS\system32\OLEPRO32.DLL
VM Arguments:
jvm_args: -Dexe4j.moduleName=c:\progra~1\azureus\azureus.exe -Dexe4j.tempDir=C:\DOCUME~1\Abhuday\LOCALS~1\Temp\e 4j43.tmp_dir28904 -Xmx128m -Duser.dir=c:\progra~1\azureus\ -Dazureus.nativelauncher=1
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=c:\progra~1\azureus\.\.;C:\WINDOWS\system32;C :\WINDOWS;C:\WINDOWS\System32\Wbem
USERNAME=Abhuday
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 14 Stepping 8, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 family 6, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 1046572k(567004k free), swap 2516752k(2076204k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_01-b06) for windows-x86, built on Mar 14 2007 00:24:02 by "java_re" with unknown MS VC++:1310
the error file name is:"hs_err_pid2400"
Now the PC does not crash but only Azureus crashed without any error message...it just closes...
