Old 02-07-2007, 09:21 AM   #1 (permalink)
Default c drive not opening on double clicking
i have loaded win xp n i m not able to open the drive by double clicking(i have to right click n select open). it shows access denied. i had similar problem with other partitians but they started working after formatting. is there any way to solve this without formatting the drive??
kooabs03 is offline
Old 02-07-2007, 02:12 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: c drive not opening on double clicking
use
chkdsk
to scan for errors in Drive C
satyamy is offline
Old 02-07-2007, 02:18 PM   #3 (permalink)
Old is Gold
prem4u's Avatar
is autoplay option is coming in right click menu on drives...???????
prem4u is offline
Old 02-07-2007, 03:21 PM   #4 (permalink)
Heres the solution Dude :-
Go to start Then Open run and Type , Regedit n then go to :-
[HKEY_CLASSES_ROOT\Directory\shell]
Then in the Right hand Side change the Value of default to 1.
Then go to
[HKEY_CLASSES_ROOT\Drive\shell]
And in the right hand side change the Value of defalut To 1 .
Thts It ..
iceeeeman is offline
Old 03-07-2007, 09:18 AM   #5 (permalink)
[quote=iceeeeman]
could not find HKEY_CLASSES_ROOT\Directory\shell directory. found HKEY_CLASSES_ROOT\Drive\shell n changed value of shell to 1
kooabs03 is offline
Old 03-07-2007, 12:16 PM   #6 (permalink)
Dude copy/paste the following code in notepad
Windows Registry Editor Version 5.00
@="1"
@="1"
Save It by any name , BUT THE EXTENSION SHOLUD BE .REG
Finally double click on it n then click on Yes.
Old 04-07-2007, 07:08 PM   #7 (permalink)
done that but it still gives the error
on double clicking
kooabs03 is offline
Old 04-07-2007, 08:26 PM   #8 (permalink)
ayush_chh's Avatar
may be here is your answer...
Unable to Open Drives by double clicking it...
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 04-07-2007, 08:33 PM   #9 (permalink)
Dude i m Sure this will work..............
Before Performin This Create a backup of ur registery.
Go to Run n then type regedit then go to :-
[HKEY_CLASSES_ROOT\Directory]
Expand it and then delete the Key Shell
Then Open Notepad and then copy/paste the following code in it :-
@="1"
[HKEY_CLASSES_ROOT\Directory\shell\find]
"SuppressionPolicy"=dword:00000080
[HKEY_CLASSES_ROOT\Directory\shell\find\command]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
  00,5c,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,2e,00,65,00,78,00,\
  65,00,00,00
[HKEY_CLASSES_ROOT\Directory\shell\find\ddeexec]
@="[FindFolder(\"%l\", %I)]"
"NoActivateHandler"=""
[HKEY_CLASSES_ROOT\Directory\shell\find\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Directory\shell\find\ddeexec\topic]
@="AppProperties"
Save it by any name But the extension Should be .reg.Finally Double click on it and then click on Yes .
Now Go to :-
[HKEY_CLASSES_ROOT\Drive]
Expand it and then delete Shell Key from it .
Now Open Notepad And then copy/paste the following code in it :-
@="Drive"
"EditFlags"=hex:d2,01,00,00
[HKEY_CLASSES_ROOT\Drive\DefaultIcon]
  00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,00,\
  65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,38,00,00,00
@="1"
[HKEY_CLASSES_ROOT\Drive\shell\DosHere]
[HKEY_CLASSES_ROOT\Drive\shell\DosHere\Command]
@="%windir%\\System32\\cmd.exe /k cd \"%1\""
[HKEY_CLASSES_ROOT\Drive\shell\find]
[HKEY_CLASSES_ROOT\Drive\shell\find\command]
  65,00,00,00
[HKEY_CLASSES_ROOT\Drive\shell\find\ddeexec]
[HKEY_CLASSES_ROOT\Drive\shell\find\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Drive\shell\find\ddeexec\topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\Drive\shellex]
[HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers]
[HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers\Kaspersky Anti-Virus]
@="{dd230880-495a-11d1-b064-008048ec2fc5}"
[HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers\Offline Files]
@="{750fdf0e-2a26-11d1-a3ea-080036587f03}"
[HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers\Sharing]
@="{f81e9010-6ea4-11ce-a7ff-00aa003ca9f6}"
[HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers\{59099400-57FF-11CE-BD94-0020AF85B590}]
[HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers\{fbeb8a05-beee-4442-804e-409d6c4515e9}]
[HKEY_CLASSES_ROOT\Drive\shellex\FolderExtensions]
[HKEY_CLASSES_ROOT\Drive\shellex\FolderExtensions\{fbeb8a05-beee-4442-804e-409d6c4515e9}]
"DriveMask"=dword:00000020
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\Sharing]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\{1F2E5C40-9550-11CE-99D2-00AA006E086C}]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\{596AB062-B4D2-4215-9F74-E9109B0A8153}]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\{7988B573-EC89-11cf-9C00-00AA00A14F56}]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\{93CCF120-E053-45CA-B7E0-7DC963928598}]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\{ECCDF543-45CC-11CE-B9BF-0080C87CDBA6}]
[HKEY_CLASSES_ROOT\Drive\shellex\PropertySheetHandlers\{fbeb8a05-beee-4442-804e-409d6c4515e9}]
Hope This Helps
Old 04-07-2007, 09:50 PM   #10 (permalink)
thnx 4 ur help(didn't try this one though). there was a file autorun.inf , deleted it, rebooted the system n its working
kooabs03 is offline
Old 04-07-2007, 11:53 PM   #11 (permalink)
Hey Dude Good to hear Tht u have Solved Ur problem ENJOY and if u r havin any more probs just Post them here .
Old 05-07-2007, 07:03 PM   #12 (permalink)
Booting Nicotine!!
spironox's Avatar
Wink Re: c drive not opening on double clicking
@="1"
  65,00,00,00
@="Folders"
@="AppProperties"
Now Go to :-
@="Drive"
@="1"
  65,00,00,00
@="Folders"
@="AppProperties"
Hope This Helps
one of the most excellent solution to the problem i guess wil be rep u man awesome really awesome
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 05-07-2007, 08:08 PM   #13 (permalink)
Wise Old Crow
blueshift's Avatar
ya sure..rep him.
http://twitter.com/blueshift155
blueshift is offline
Old 05-07-2007, 11:23 PM   #14 (permalink)
THNX spironox
Old 11-07-2007, 06:29 PM   #15 (permalink)
Booting Nicotine!!
spironox's Avatar
hey iceeeeman i want to know what about other frives i mean D: E : F: etc what should be changed i mean will the sol provide solution to all drives probs !!
spironox is offline
Old 11-07-2007, 08:14 PM   #16 (permalink)
Ya man this solution is for all drives
Old 17-11-2007, 06:09 PM   #17 (permalink)
try this it will work
erase aurorun.inf /f /a -r
and restart your computer
try it will all drive that have this problem
himanshumaker is offline
Double clicking on drive opens search! DizitalNovice QnA (read only) 6 24-05-2007 12:01 AM
Unable to open Drives in My Comp/Explorer by double clicking infra_red_dude QnA (read only) 7 20-05-2007 08:54 AM
Unable to Open Drives by double clicking it... Ron QnA (read only) 4 19-05-2007 06:37 PM
Help me pls.. Application doesnt start after double clicking abhi99_iitg Software Q&A 3 23-09-2006 04:53 PM
- by Niilesh
