Old 30-06-2007, 12:35 AM   #1 (permalink)
Default help me out to make xp cd..
i need to make a cd that will have xp as well as all my motherboard drivers on one cd..so that i dont have to go for installing drivers every time i install xp.,they will be installed during xp installation
jyoti_ranjan87 is offline
Old 30-06-2007, 12:48 AM   #2 (permalink)
sam_1710's Avatar
Default Re: help me out to make xp cd..
search this forum for "nlite" (without the quotes that is..)
official site : http://www.nliteos.com/
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
sam_1710 is offline
Old 30-06-2007, 10:55 AM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
^^ nice one.
Also try for PE Builder
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 30-06-2007, 11:43 AM   #4 (permalink)
Dude u may use Nlite to Add ur computer drivers to windows xp Bootable cd and if u wanna add ur own customized files ,For eg. Shell32.dll
After u have made the cd with ur own required Drivers save it on ur hard Drive ,browse the cd and then go to 1386 folder and search for the same file name i.e shell32 without the extension ie .Dll..when windows Finishes searchin u will find "shell32.dl_" ,Now "shell32.dl_" is zipped in windows setup .You have to convert the "shell32.dll" file to "shell32.dl_" format ..to do this first copy ur modified "shell32.dll" to any drive ...for eg c:,Now:-
1.Go to run n then type cmd
2.then type cd.. 2 times , now the drive where u have installed windows will appear( i Suggest u copy the modified file to same Drive )
3.Now write the address of ur modified file and also its name then type makecab file_name.For eg. I saved my modified file in c: as shell32.dll so i will write
C:/> makecab shell32.dll
The file will b convetred to "shell.dl_" format .Now simply browse ur windows xp setupo folder n replace the old "shell32.dl_' with the new one .
iceeeeman is offline
Old 30-06-2007, 07:30 PM   #5 (permalink)
see all this year digit magzines.
abhijangda is offline
Old 05-07-2007, 01:47 AM   #6 (permalink)
Is actually a real word..
u could try Symantec's Ghost (or save n restore as it is now called)
Liggy is offline
Old 12-07-2007, 09:50 PM   #7 (permalink)
Thank u guys for helpin me out.......
How to make D to C!!! kato QnA (read only) 11 05-12-2005 09:41 AM
How to make it? rajas700 QnA (read only) 8 07-09-2005 06:55 AM
How to make it? rajas700 QnA (read only) 2 05-09-2005 11:19 AM
pls help to make jitu_mania QnA (read only) 1 22-05-2005 01:37 AM
- by Niilesh
