Old 30-06-2007, 12:13 AM   #1 (permalink)
You'r Born Free
int86's Avatar
Default Problem in making VCDs
I have few AVSEQ.DAT files. When I try to make a VCD with Nero, it takes around 20 minutes to re-encode it, then it burns.
Since those are already dat files, cant those 20 minutes be saved.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 30-06-2007, 12:19 AM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Problem in making VCDs
I think there nero will popup a message regarding bit rate or something as not standard .. just cancel it and check. To experiment for quality, save it as a CD image.
EDIT:Its been long since I used Nero for VCD's. Dono if there is any changes to nero recode.
Charan is online now
Old 30-06-2007, 12:28 AM   #3 (permalink)
You'r Born Free
int86's Avatar
No popups.
Yes I am talking about why to waste 20 min in making image.
int86 is offline
Old 30-06-2007, 07:13 PM   #4 (permalink)
try to reinstall nero
abhijangda is offline
Old 02-07-2007, 12:01 AM   #5 (permalink)
CA50's Avatar
[ASSUMING THAT U HV NERO ] no don`t do that all u hv 2 do is that when u move ur cursor over "make a VCD" then click on "nero express" instead of "nero vision" after that u hv 2 add the files and hit burn. plz say thanks if this helps
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 02-07-2007, 01:50 AM   #6 (permalink)
You'r Born Free
int86's Avatar
@CA50
Thanx buddy
Your way worked perfectly, it was like a secret menu to me.
int86 is offline
Old 03-07-2007, 10:29 PM   #7 (permalink)
CA50's Avatar
nice 2 read that
| Nokia 2700c |
CA50 is offline
Prob in making VCDs frm handycam cassettes mayur_digitized Mobiles and Tablets 2 18-05-2007 05:44 PM
Ripping VCDs anantkhaitan Open Source 5 08-05-2007 11:14 AM
Making VCDs under Linux JGuru Open Source 3 12-06-2006 08:39 AM
problem in making windows xp bootable cd with sp2 integrated gary4gar Software Q&A 15 07-11-2005 05:59 PM
Please help regarding VCDs !! nipun_the_gr8 QnA (read only) 5 24-05-2005 03:15 PM
- by Niilesh
