29-06-2007, 07:03 PM
Om Ma Ni Pä Me Hum
driver problem ... urgent
i have problem with usb driver. it shows unknown device. cnt update driver and also tried sys restore. i use xp with sp2 and usb for w700.
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
30-06-2007, 07:47 PM
Om Ma Ni Pä Me Hum
Re: driver problem ... urgent
ok dead people give me some ans . . the mobile is connected as it shows charging but cnt open it as usb is shown as unknown . . doesnt install new driver also . . wat to do . .
30-06-2007, 09:36 PM
Host4Cheap.org
Learn to respect people maybe  and YES! uninstall Attitude
http://www.host4cheap.org/
01-07-2007, 08:38 PM
Om Ma Ni Pä Me Hum
sorry for it . . the usb dev is my SE W700 and the usb cable is connected as it shows chargin . . prob is that it cnt read my usb ie phone memory as it says it is unknown dev and doesnt even ask for driver . . other dev like usb stick is workin fine . . i m not able to connect to net because of it . . please help . . ps i tried in my friends comp same prob . .
02-07-2007, 10:25 PM
Is actually a real word..
03-07-2007, 12:01 AM
y dont u try using d add new hw option in d ctrl panel, if it is unable 2 dtect ur handset and then asks if it is plugged in and then when it asks u if u got the drivers u can provide the location to the drivers
03-07-2007, 01:01 AM
TechTin.com
Try after reinstalling driver from the installation CD.Than post again.
No one will come to help you with ur this tounge.
03-07-2007, 09:53 AM
u cant expect an answer in less than one hour . .mods will mostly give u an intimation ,
BTW , try uninstalling the device from device manager and also uninstall the drivers . restart , let windows detect something . then install drivers again..
since u r having same prob in frens house , u may have to consult the manufacturer or u have some settings wrong in ur phone itself..
03-07-2007, 12:17 PM
Om Ma Ni Pä Me Hum
i m really thankful for all ur answers n i m really sorry for being rude   ....... my phone prob was gettin on my nerves so . . pardon me . . it still doesnt work . i have mailed to the SE support . . i m waitin for the reply .. i tried every thing now i need to try in linux . . which is givin me tough time to install . . anyways if u do come across new sol do put it in . . . thank u guys for ans again . . .
ps i m using opera mini so . .
03-07-2007, 11:52 PM
Maybe the cable's bad.If you have a bluetooth dongle try using bluetooth and see.
05-07-2007, 01:18 PM
Om Ma Ni Pä Me Hum
it works now i just twisted the pins in the usb wire it seems to work for now . but the opera n firefox dnt open any site only ie explorer is workin but too slow . is there some way to make it work fast.
