Old 29-06-2007, 09:21 AM   #1 (permalink)
Default need to CUT certain scene frm a Video- using XP- Reg
dear,
i was used VcdCutter before to cut certain scenes frm a movie. but nw dont knw wht happnd, its not working. and unfortunately i have lost those vcdcutter directory itself.
though can anyone help me in this, by providing a new version on the VcdCutter or even any other sharewares?
be kind.
waiting with patience
thanking u n advance
mobileman
mobileman is offline
Old 29-06-2007, 11:12 AM   #2 (permalink)
The Sexy Beast
Default Re: need to CUT certain scene frm a Video- using XP- Reg
use virtual dub it's free but supports only avi output
vcd cutter's latest version is 4.03(but that's released in 2004)
u can use vcd cutter in XP too first download the new version by searching in google then after installing right-click the main vcd-cutter exe file and go to the compatibility tab and use the option run in then select windows 98 that will do it or check the turn off advanced settings option
ratedrsuperstar is offline
Old 02-07-2007, 01:08 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
virtual dub is better than vcd cutter .........
ax3 is offline
Old 02-07-2007, 05:06 PM   #4 (permalink)
ramprasad's Avatar
I have used both VCD CUtter and Virtual dub.....
From what type of files do u want to make clippings (MPEG1,MPEG2 or DAT(mpeg1))
ramprasad is offline
Old 02-07-2007, 06:06 PM   #5 (permalink)
slugger's Avatar
use VCD gear
http://vcdgear.com/
u will have to use the sample clip editor option to do the clipping
and it is a FREEWARE better than any shareware
btw can anyone tell me how to make a word into a link
the <a href="">word<\a> tag seems not to be working here
slugger is offline
Old 03-07-2007, 07:19 AM   #6 (permalink)
dear slugger,
i have tried to download.but page cannot shows.if u r having, could u share to me?
and ramprasad, i need to cut/make clips frm dat(movie cd)s.can u provide ?
waiting for repliy
mobileman
Old 03-07-2007, 12:17 PM   #7 (permalink)
slugger's Avatar
heres d direct link. shud work
http://www.vcdgear.com/files/vcdgear355.zip
slugger is offline
Where can I get The Scene Season 1? aditya.shevade QnA (read only) 4 07-05-2007 11:25 PM
Windows vista dream scene beta smackeroo Software Q&A 9 10-02-2007 02:35 AM
In case u have not heard of "The Scene". titun Random News 11 29-11-2006 10:26 PM
- by Niilesh
