28-06-2007, 08:25 PM
Gracias Senor
Post Hibernation ???
Hi all..
I use to hibernate my PC always..cos it saves my time and also saves my work..but the problem is once I boot my system after hibernation, I get the screen which says resuming windows..after this screen my monitor goes blank and al the front panel lights starts blinkin for 5 minutes and then my monitor shows up the desktop.
We use to hibernate to save time..but cos of this problem its wastin my time cing the blank screen 4 5 minutes..this is really annoyin..
Is thr any solution 4 this..
Pls help me out..
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
28-06-2007, 08:54 PM
Rubik's Uncle!!
Re: Post Hibernation ???
Looks like you may be having a corrupt driver. Check Chipset, Display and modem drivers, Try reinstalling those drivers. Disable modem and then hibernate and check.
Edit : These kind of problems occour when the system cannot restore a hardware to its pervious state before hibernation.
28-06-2007, 09:14 PM
Gracias Senor
Thnx 4 the quickest reply..
BTW my modem is already disabled..also now tryin to update my drivers..wil revert bac if it works
28-06-2007, 09:20 PM
Is actually a real word..
could be low disk space on the C: drive, how much v ram do u have set up.
28-06-2007, 09:59 PM
God of Mistakes...
I have another problem with Hibernation.
Whenever I click on Hibernate, it shows Hibernating.... & after that it restarts . How this can be fixed ??
28-06-2007, 10:34 PM
Rubik's Uncle!!
Yes this could also be a valid reason. Try disabling Hibernation , restart , and then enable it back.
28-06-2007, 10:43 PM
Genius in making mistakes
size of hiberfil.sys = size of RAM
29-06-2007, 04:24 AM
Macboy
That's one weird thing actually. The one's with the most RAM have to wait the longest for the system to boot. And now that Vista uses up all the RAM with its SuperFetch thing, it is really long on a 2GB system...
I'm like a bird... :)
04-07-2007, 12:04 AM
dreams how's it going did you find a solution yet?
shirish_nagar are you still having issues as well?
04-07-2007, 10:35 PM
Possible Causes:
Low RAM
Low DSK Space on C
C may need defrag
Corrupt Drivers
May be some LAN connection. (many times happens on my dad's lappy).
KDE on ArchLinux
05-07-2007, 09:33 PM
Gracias Senor
sorry guys..was little busy wit my work..
I updated my chipset drivers and now after hibernation my monitor completely turns off..after few secs turns ON.(No more blinkin LED lights in frnt panel)
Also my C: capacity is very low..so wil try to inc its size or try to defrag and hv to check..waitin for this weekend.
05-07-2007, 09:40 PM
One method to free-up space on C: is to shift the Temporary (Windows) directories to another location. Also you can change the IE temp folder to free-up some space.
KDE on ArchLinux
05-07-2007, 11:39 PM
Booting Nicotine!!
try googling hibernation windows vista u will see what exactly hibernation does ! that might help u to understand the problem!
solution lies in problems sometimes !
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
05-07-2007, 11:44 PM
delete files from c: or copy/paste them to other drives to save space if then too u r facing the problem try installin Windows on some other drive ..
P.S-: Also Check ur ram Sticks as Ram plays a Major Role for Hibernation
