Results 241 to 270 of 276
04-10-2011, 02:09 PM #241
re: [Windows XP] FreQuently AsKed ProBlems WITH SoluTions...
how to repair the os....does it have any inbuilt utility to do so?
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
04-10-2011, 02:19 PM #242
You have to insert the Windows 7 dvd. wait for everything to load then on main screen you have to click repair. Donot click install.
Follow me on Twitter: http://twitter.com/wuodland
Have a look at my Photography page: http://bit.ly/N2aMTi
04-10-2011, 02:35 PM #243
04-10-2011, 06:19 PM #244
oohh that repair option...got it
18-11-2011, 05:51 PM #245
I have Balanced Power Plan selected for my PC , which has "Turn off Monitor" set to 1 Minute. This is Ok except for the time when i am studying from some PDF, i have to move the mouse [ or keep a video running at background ] to keep the monitor open.
Is there a Windows 7 Gadget which would enable me to quickly switch between Power Plans ?
Already got a sloution whcih i think is good enough
http://powerschemeswitcher.codeplex.com/i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz || XFX ATI HD5670 1GB
WD 2TB + Seagate 2 TB x2 + Seagate 1 TB + Seagate Freeagent 1 TB + Buffalo USB3.0 1 TB
Corsair CX400 || Zebronics Bijli || Samsung P2350 || Altec Lansing VS2621
My Speedtest :D || LG Optimus L9 P765
18-11-2011, 06:05 PM #246
Nice find. Thanks for sharing.
Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
Android: Galaxy R | Galaxy Y
18-02-2012, 05:14 PM #247i love bakwaas
- Join Date
- Jan 2012
- Location
- bangalore
- Posts
- 10
Been trying to install ccleaner on my cousins netbook but its been stuck at this point for some time.
it installed perfectly in mine.
also cant install foxit reader and glary's utilities.
7 zip was successful though. any help ?
cant upload image as attachment to show
18-02-2012, 07:17 PM #248
did ya try in safe mode? are there any.process using 100% cpu?
18-02-2012, 08:24 PM #249
I don't know what i did but now I'm not able to start Task Manager. Any help?
Also, is there any option/software which can Hard Reset Windows 7?
18-02-2012, 09:39 PM #250
@tarun any specific error being shown?
[SOLVED] task manager not working - Tech Support Forum
try restoring to a older date for reset. no specific way.
18-02-2012, 11:56 PM #251
^^ no error. Its just that the task manager button can't be clicked. neither does it appear when pressed ctrl+alt+del.
How do I restore it to an older state?
19-02-2012, 12:18 AM #252
The android game I made - MultiPingPong
19-02-2012, 09:02 PM #253i love bakwaas
- Join Date
- Jan 2012
- Location
- bangalore
- Posts
- 10
in mine another problem now with built in webcam(Acer 5542 laptop)
nothing seems to work eg:manycam, yawcam etc
Have installed all drivers and the Device Manager says "This device is working properly".
Webcam test just shows a black image and Chatroulette shows your webcam has no activity.
Acer's own Crystal eye webcam software doesnt seem to run.
It was working well until recently
20-03-2012, 08:16 PM #254
Download latest drivers from here and try
Acer Support: Downloads & Support Documents - Notebook / Aspire / Aspire 5542
25-05-2012, 11:44 AM #255Right Off the Assembly Line
- Join Date
- Mar 2012
- Location
- Jaipur
- Posts
- 8
Very knowledgeable and informative blog.My favorite one is of error message because my computer generally show this message.Thanks for solution.
02-12-2012, 09:23 PM #256
I've win xp as my OS. When I switch on my system, it says that " your computer wasn't switched off properly etc etc……
I tried all the means to switch it on( safe mode, last known good configuration, start Windows normally)
It again restarts and comes back to the same dialogue screen and the loop goes on.
Help !
03-12-2012, 06:20 AM #257
HDD might have bad sectors or even a virus(strange enough even on my old PC I used to get into a boot loop after pc hrs shutdown directly for power cut or other reason)
the fact that safe mode doesn't work makes me feel even stronger about the virus thing.
see if you can repair windows installation with the windows xp CD. I dont think you are left with many other options other than clean format.Follow me on Twitter: http://twitter.com/wuodland
03-12-2012, 08:20 AM #258
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Making of "The Cyclone"
Welcome to "The Cyclone"
03-12-2012, 09:07 PM #259
Thanks for the replies, guys !
@gameranand mine is a core2duo with only 1 gb ddr2 ram
Guess win7 won't work in my pc
03-12-2012, 11:08 PM #260
Its going to run quite fine. Though 1 gb is a little less, it shouldnt be much of an issue i believe. As long as you dont have an antivirus. I have had Win7 using ~25% og the available 4gb, but I think it might automatically scale down the memory usage, if it sees any issues. Not sure about it though.
HP Pavillion dv4 3016tx | i5 2.33GHz | ATI HD6750M 1GB | 4GB RAM | 500GB HDD
Grado SR60i | Panasonic HJE120 | Soundmagic E10
Lumia 920 | Nokia N70 | Sony Ericsson Xperia Ray
Canon EOS 600D 18-55 Kit lens
Me @ Flickr
04-12-2012, 08:17 AM #261
Thanks Pranav. I'm not confident enough to load Win7 in my PC => worried about the performance.
I've Titanium AV loaded in my pc. It was pretty gud,dont know how it got affected by virus
06-12-2012, 01:45 PM #262
The problem now is - my Win XP bootable cd is not getting detected, so I'm unable to re-install Win XP
06-12-2012, 02:36 PM #263
09-12-2012, 12:43 PM #264
Re: [Windows XP] FreQuently AsKed ProBlems WITH SoluTions...
Used ultimate boot cd to format c drive. Still unable to instal win xp.
Error 000007 is coming up .
09-12-2012, 01:02 PM #265
Guys still use XP, I am surprised.
09-12-2012, 01:30 PM #266
Didnt know that it is a crime to use xp these days! :O
10-12-2012, 07:42 PM #267
10-12-2012, 09:32 PM #268
11-12-2012, 09:27 AM #269
11-12-2012, 11:26 AM #270
If you are trying to install the Windows XP from scratch on the laptop, please BE SURE that you put the Hard Drive on "Compatibility" mode in BIOS, which was defaulted to "AHCI" (Compatibility is also known as IDE).
Otherwise, you will experience the "blue screen" issue. To change that setting, you need to do the following:
1. Press F2 when booting up the computer
2. Select 'Config', then 'Serial ATA (SATA)'
3. Change controller option to 'Compatibility' / 'IDE'
source
This happened with me, after XP loads setup files, it'd crash - BSOD. reason was - my HDD was in AHCI mode in BIOS (windows Vista/7)
And if anyone dont have solution for problems posted here, dont say "upgrade/buy new stuff..."★--------------�--------------★
ASUS K53SV SX520D + BF3
15-12-2012, 06:33 AM
Frequently Asked Questions (FAQ's)
By FilledVoid in forum Open SourceReplies: 47Last Post: 27-03-2010, 03:57 PM -
Windows Vista Sp1 Problems and solutions.
By manish646 in forum Software Q&AReplies: 3Last Post: 02-12-2008, 11:37 AM -
By manish646 in forum Technology NewsReplies: 3Last Post: 02-12-2008, 11:37 AM -
Most frequently asked questions
By anomit in forum QnA (read only)Replies: 4Last Post: 16-08-2005, 12:55 AM -
MANY PROBLEMS NEED SOLUTIONS
By wizrulz in forum QnA (read only)Replies: 7Last Post: 21-04-2005, 11:43 PM
LinkBack URL
About LinkBacks
