Results 31 to 60 of 276
30-06-2007, 02:18 PM #31In The Zone
- Join Date
- Jun 2005
- Posts
- 205
Re: MUST READ: FreQuently AsKed ProBlems WITH SoluTions...
great work vishal, i appreciate it..
keep it going..
30-06-2007, 02:25 PM #32
gr8 bro
Dell 15z + 2 TB WD+ 830 256 GB || iPhone 4 32 GB || Beyerdynamic DT990 Pro 250 Ohm
30-06-2007, 02:39 PM #33
nice post Vishal !!
30-06-2007, 03:00 PM #34
My pleasure guys. Its all bcoz of ur love and support.
Blog: http://www.AskVG.com/
04-07-2007, 09:28 PM #35
Gr8 post!
PicoVico.Com - SlideShow Maker
04-07-2007, 11:18 PM #36
greaaaaaaaaaaaaat post --------cooooolllll
05-07-2007, 08:22 AM #37
simply great..............thanx vishal
05-07-2007, 08:49 AM #38
Rankeshwar Singh Dadhwal
Consultant Engineer
05-07-2007, 09:31 AM #39
u r welcome guys.
05-07-2007, 10:37 AM #40Broken In
- Join Date
- Dec 2005
- Location
- goa
- Posts
- 162
Fantastic Vishal,
You are really good, helpful and hardworking guyKeep :smile:ing
05-07-2007, 11:47 AM #41
regarding pt.14... some one messed with my frnd's pc and changed the BIOS password. i tried resetting it by removing the battery first but in vain. then i changed the jumpper setting to reset the password. so i think only removing the cmos battery may not help always.
eXPerience is what a MAN learn's fROM.....
05-07-2007, 12:12 PM #42Right Off the Assembly Line
- Join Date
- Jul 2007
- Location
- guwahati,Assam
- Posts
- 18
great work! it is an uncuttable thread
15-07-2007, 12:21 PM #43Right Off the Assembly Line
- Join Date
- Mar 2004
- Posts
- 4
Due to some mallecious activities my computer is not showing run command in start menu (aslso foder option and task manager is disabled). so i am unable to run regedit command to restore folder option and task manager.
how to restore run command
how to restore run command in start menu which was disabled due to some virus asctivities.Last edited by Pradeep Kumar KD; 15-07-2007 at 12:21 PM. Reason: Automerged Doublepost
15-07-2007, 12:39 PM #44
^^Goto group Policies and from there u can enable these options in Administration
15-07-2007, 01:28 PM #45
@Pradeep Kumar
Pls visit:
TUTORIAL: All Kinds of Restrictions for Windows XP/2003Blog: http://www.AskVG.com/
18-07-2007, 06:44 PM #46Broken In
- Join Date
- Feb 2007
- Location
- Hyderabad
- Posts
- 152
20. I'm using Windows XP and the desktop icons suddenly started showing an ugly background rectangle behind the text. How can I make the text transparent?
Sol: Type "sysdm.cpl" in RUN dialog box and press <Enter>. Now goto "Advanced" tab, click on "Setting" button in "Performance" section and enable the option "Use drop shadows for icon labels on the desktop".
with this help i am unable to solve the problemOnce a new technology rolls over you, if you're not part of the steamroller, you're part of the road
18-07-2007, 07:00 PM #47
^^ Make sure you hv not enabled option "Lock Desktop Icons" in desktop context menu. If its not enabled then goto Desktop properties and make sure that no "Active desktop" content is enabled.
19-07-2007, 03:27 AM #48Broken In
- Join Date
- Feb 2007
- Location
- Hyderabad
- Posts
- 152
Originally Posted by Vishal Gupta
thanks it has solved..
lock desktop was enable.Once a new technology rolls over you, if you're not part of the steamroller, you're part of the road
20-07-2007, 11:28 AM #49
@guptaji .......... u really spend more time on NET & this FORUM 2 .........
great effort frd ......... thanx .........Last edited by ax3; 20-07-2007 at 12:42 PM.
... W H O T ...
20-07-2007, 03:21 PM #50
^^ Thank u.
31-07-2007, 12:16 AM #51
when right click on any image to set as background this option is not present in right click
13-08-2007, 07:03 PM #52
That's great work Vishal Its very Imp for me.
I have one more problem . When I start my system each time I have to write explorer.exe in Task manager/new process. I think some how the command explorer.exe get disabled. Plz tell me activate it so that I don't have to write explorer.exe again and agian. thank u.
26-08-2007, 03:19 PM #53Right Off the Assembly Line
- Join Date
- Apr 2007
- Posts
- 13
Thanks a lot for the info.
28-08-2007, 11:43 PM #54
21-09-2007, 04:19 PM #55
hey buddy...
Can we schedule a command from regedit........PicoVico.Com - SlideShow Maker
27-10-2007, 12:46 AM #56
First post updated with the solution of "Orkut.com", "Youtube.com" and "Firefox" blocked in system...
27-10-2007, 12:49 AM #57
Thanks Vishal for the solution
the cake is a lie
621311.251521
27-10-2007, 01:09 AM #58
^^ Welcome buddy.
27-10-2007, 03:17 PM #59
good job
great workwww.techbloger.in
www.gedgetsworld.in
Add Me on Facebook - http://www.facebook.com/mahavircomputers
Follow me on Twitter- http://www.twitter.com/techeblogger
30-10-2007, 04:34 PM #60
Good Effort my dear friend.
S.N. ASHOKKUMAR
"Failure should never go to your Heart
Success should never go to your head"
15-12-2012, 06:33 AM
Frequently Asked Questions (FAQ's)
By FilledVoid in forum Open SourceReplies: 47Last Post: 27-03-2010, 03:57 PM -
Windows Vista Sp1 Problems and solutions.
By manish646 in forum Software Q&AReplies: 3Last Post: 02-12-2008, 11:37 AM -
By manish646 in forum Technology NewsReplies: 3Last Post: 02-12-2008, 11:37 AM -
Most frequently asked questions
By anomit in forum QnA (read only)Replies: 4Last Post: 16-08-2005, 12:55 AM -
MANY PROBLEMS NEED SOLUTIONS
By wizrulz in forum QnA (read only)Replies: 7Last Post: 21-04-2005, 11:43 PM
LinkBack URL
About LinkBacks
