24-06-2007, 12:32 PM
Please Help my out
Hello Friends,
i formated my system and installed a fresh XP. now i am getting a strange error.
i am getting the below dialog box
c:\docume~1\MEHTA\LOCALS~1\TEMPSV~1.EXE
THE NTVDM CPU has encountered an illegal instruction.
C5:0578 IP:0283 OP:63 6F 6c 72 chose 'Close' to terminate the application
close ignore
please help me out and another problem is that some blue screen comes and it get restart automatically.
pls help me friends
thanks in advance
Once a new technology rolls over you, if you're not part of the steamroller, you're part of the road
24-06-2007, 04:04 PM
Re: Please Help my out
simple way is to format your c drive again ...
24-06-2007, 04:06 PM
Re: Please Help me out
i have already done twice.
24-06-2007, 07:53 PM
Random Username
Even I had this problem previously. A dialog box will give two options :Close and Ignore. Clicking on ignore should make your program run fine. After I formated my C: drive and reinstalled Xp, I stopped getting this message.
About the blue screen....when does it appear? If it appears randomly, it can probably be an overheating problem.
25-06-2007, 05:37 AM
Is actually a real word..
after installing windows did you install the drivers, more importantly did you install the chipset driver then restart the system? when you formatted did you have any non-essentials plugged into the system, Ethernet, exra USB devices (camera, printer etc). was it a full format or a quick format... I would suggest the full format if you have not already done so. Just a quick question why did you format to begin with?
25-06-2007, 09:14 AM
After installing windows XP i straight away install all the graphics and audio drivers and then ethernet drivers. ethernet was their when formatted and i have done full format.
No it dont appears randomly
Reason: Automerged Doublepost
25-06-2007, 09:43 AM
you have got virus or spyware ...the virus if present in the other drives can also cause harm sometimes ...in rare cases
and have you formatted your complete system ?
this link might help you
http://www.techspot.com/vb/all/windo...truction-.html
Be like a postage stamp-stick to one thing until you get there.
25-06-2007, 09:13 PM
you said you installed graphics and sound (drivers), but if you don't install Chipset that is where a lot of issues come from. and if you have your ethernet unplugged while doing the format and reinstall you should not have to worry about virus. full format you are wiping the whole disk right, not just a single partition. yes, no, maybe so....???, assumming u have XP sp2 disk try running sfc /scannow.
26-06-2007, 04:21 AM
what chipset you are talking about? can you tell what is this chipset.
i have xp2 only
i have formatted only c drive and i dont have any virus in my system.
26-06-2007, 11:33 PM
i have xp2 only
Well then this is probably the issue. the chipset is basically a driver for your motherboard, and needs to be installed 1st. so that when u install othe drivers the PC will function correctly. it is specifically made for the mobo. u need to know the exact mobo you have. is your computer a name brand , like a dell, if so you should be able to go to their homepage and download the chipset. if your PC is homebuilt you should of had a disk that came with the mobo. if you open up the PC there should be a serial number on the board and you need to to know the make, sometimes you might get lucky and see a sticker that says (example) Intel 865g or something simillar. open the case and see if you have a sticker located on the printer port (pink connection), if so this should narrow it down for you.
* try to get CPU-z (program) click mainboard tab and it should tell you your chipset, then see if there is an updated driver.
27-06-2007, 02:14 PM
Thanks a lot for your suggestion. i will keep this in my mind and suddenly the dialogue box has disappeared
28-06-2007, 04:09 PM
i have got that message once again i will take all ur suggestion and try to fix it out
28-06-2007, 09:24 PM
did u try cpuz to find the correct chipset? there may also be a firmware upgrade for the mobo that might be need to install some of the newer drivers
30-06-2007, 12:17 AM
i had drivers in the CD which i have install.
but i will goto website and download the latest drivers for mobo and try installing that.
30-06-2007, 12:24 AM
u need to install the chipset drivers before u install ne other drivers..
n the blue screen usually appears when there is a problem with the graphics drivers..
n for the graphics drivers to work properly chipset drivers must be installed....
that's why u r facing these kind of problems..
30-06-2007, 05:02 PM
okie i have downloaded the latest support from the websit and i have also update my BIOS.
is it necessary to keep update BIOS along with CHIPSET
01-07-2007, 08:07 PM
It is best to keep things like that up to date, cuz when you download updates through MS, the MS updates are going to assume your system has latest drivers.... I am waiting for a reply from Vishal Gupta about a question pertaining to BIOS & Chipset updates to clarify .
01-07-2007, 08:12 PM
reinstall xp.
03-07-2007, 05:42 PM
#19 (permalink)
Tech Savvy
Hello Friends,
close ignore
pls help me friends
thanks in advance
its very simple buddy , dont fight with your operating system , try to change your RAM. i dont know whats the exact reson for the exe problem. But for sure the memory dump problem which throws the blue screen s due to the RAM error. Better try to change the RAM with any of your friends and check it out... happy computing
Join msminds and get all the Tech stuff right into your inbox
http://www.groups.yahoo.com/group/msminds
05-07-2007, 04:03 PM
#20 (permalink)
thanks a lot as of now none of problems are coming i suppose its solved.
now their some dialogue box coming regarding genuine Windows XP. how can i diable that pop up
06-07-2007, 12:43 AM
#21 (permalink)
buy a valid ver of windows...  or download a crack.
06-07-2007, 11:23 PM
#22 (permalink)
what i had was a valid key but dont know what happen this time coz before this i never got this problem
08-07-2007, 08:39 AM
#23 (permalink)
how many times did you use the disk to reload? you can try seeing if you can swap it where you bought it, otherwise you'll have to pay... hence the crack
08-07-2007, 02:13 PM
#24 (permalink)
Booting Nicotine!!
hey check private msg that i have send to you
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
