Old 24-06-2007, 08:39 AM   #1 (permalink)
Default need to knw the difference among mp3 and wma ?
Hi all,
I wanna knw, wht s the difference between mp3 and wma formatt cds.
someone told me tht, wma cds will bear 2000+files of songs
can anyone guide me by providing the advantage / drawbacks among these both?
Waiting
mobileman
mobileman is offline
Old 24-06-2007, 08:56 AM   #2 (permalink)
slugger's Avatar
Default Re: need to knw the difference among mp3 and wma ?
foe info on wma u may want 2 visit dis link
http://en.wikipedia.org/wiki/Windows_Media_Audio
http://en.wikipedia.org/wiki/MP3
as 4 a wma cd can hold 2000 songs, it depends on the bitrate @ which u have encoded ur songs. lowere d bitrate gr8 d number of songs you will be able 2 hold in the cd, but it will affect d qlty of sound. MS claims dat 64kbps of wma is eq t0 160 of mp3 which will mean if 154 songs [avg 4 mins] of mp3 r burned in a cd then u will be able to burn 385 of the same using wma
but i still prefer d mp3 format
slugger is offline
Old 24-06-2007, 09:26 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Both MP3 and WMA (windows media audio)are audio codes.
1) MP3
Its compression ration is 11:1 means..if a 20 MB audio source is compressed in MP3 format at a bit rate 128kpps ,than resulting file would be around 2 MB.
It is a lossy compression..means some quality is decreased.
2) WMA
A 10 MB audio file can be compressed to max. to 7 MB in WMA format.
It is a lossless code.Means quality of sound will not decrease.
Conclusion:
MP3 format is most popular format than anyother audio format because of small size and without much difference in audio quality.
ravi_9793 is offline
What is the Difference b/w these RAM... dabster Hardware Q&A 4 28-04-2006 05:24 PM
What is the difference between C and C++? imagineer_aman QnA (read only) 21 05-07-2005 08:03 PM
difference sourav QnA (read only) 1 04-05-2005 06:02 PM
What is the difference between LCD and TFT debaisaindian TVs / Monitors 7 02-05-2005 12:48 AM
Difference... sourav QnA (read only) 3 17-04-2005 12:24 PM
- by Niilesh
