Old 22-06-2007, 11:40 PM   #1 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
Default Strange Virus In My System
I Hav Just got a virus from a mobile phone ,named folder.exe (just look like a normal folder) in My Documents folder
and this same folder is created when ever i open a folder
And More , when i search google for online virus scan the browser (i tried opera ,IE,Safari) suddenly closes .while other searched are working .
My antivirus(avast) fails to delete it after detecting.......
Please help me im in a big problem.......
Josan is offline
Old 22-06-2007, 11:52 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Strange Virus In My System
Try Scanning with Kaspersky Online scanner !!
http://www.kaspersky.com/virusscanner
or download the Trial of NOD32 or Kasoersky to install and scan for any harmfull object, also Install Spybot SnD http://spybot.info
Note turn off the System Restore before trying to scan or heal ur system !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 23-06-2007, 07:43 AM   #3 (permalink)
The Linux Man !
paragkalra's Avatar
I had same kind of virus........gave me lot of trouble.......Use Symantec 10.2 (only for vista)..........It has removed all such exe files from my comp.....Symantec 10.2 works only for vista.........
Parag.A.Kalra, The Linux Man
http://www.paragkalra.com/
In this world without WALLS and GATES who need WINDOWS! USE LINUX! STOP PIRACY! GO OPEN SOURCE!
paragkalra is offline
Old 23-06-2007, 08:27 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
I will also suggest you to do online scan.......I think @Choto Cheeta has given link which U need.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 23-06-2007, 08:43 AM   #5 (permalink)
 Macboy
goobimama's Avatar
Kaspersky is the best according to me when it comes to cleaning out an infected system. Use their 30 day trial to clean the system, and then uninstall and use a free AV system if you will.
I'm like a bird...
goobimama is offline
Old 23-06-2007, 12:46 PM   #6 (permalink)
Gangsta
Josan's Avatar
Hey Guys ,i tried the online scan but as i said ,earlier when i tries to ecess such sites ,my browser closes,
and also my taskmanger closes
But Now i hav got rid of it in a very tricky way,without using any antivirus
What i did is ---
1.i opens the Tune Up Utilitities 2007 ?(allready installed)
2.then i open the TuneUp Process Manager (Becouse My Windows task manger was not working because of this virus or it closes suddenly after starting it)
3.Then i find that 2 windows explores programs were running (normaly there sholud be only one ) it did'nt take me time to find the wrong one,then i closes this program
4.Now i searched and deleted all the folders with name New Folder.exe(thanks Windows Vista for this better and fast search)
and one other program vcdgcw32.dll (that was in system32 folder) , which was the actual virus.
5.because allready had closed the windows explorer in the taskman (which was a fake name) so no new folder created when i delete all folders with the name New Foder.exe
Like My trick!!!!!!!!!!!!!!?
Josan is offline
Old 23-06-2007, 04:02 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
moblie fone...meaning...symbian os ??
then it wont affect the windows os !!!
anyway good 2 c u have solved ur problem !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-06-2007, 05:43 PM   #8 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
What i did is ---
OK you cleared all the folder.exe files. But do you know that other allready existing exe files can also be infected?
Do a actual virus scan d00d as soon as possible. Viruses tends to infect other files too.
World is just a Quizzical Reality : Quiz_Master//Ashwin
Quiz_Master is offline
Strange virus - tell me what it is! knaadhan Software Q&A 5 28-09-2006 12:48 PM
help system infected with Win32.pinfi virus. Mangal Pandey Software Q&A 2 24-08-2005 12:56 PM
virus in System volume information folder Shikhar Software Q&A 3 16-08-2005 08:01 PM
Blaster virus causing shutdown of system jobin Software Q&A 4 24-02-2005 12:25 AM
strange error messges,funny system clocktimes.... bernie QnA (read only) 3 11-09-2004 11:46 PM
