Old 21-06-2007, 10:14 PM   #1 (permalink)
Attitude matters
Ponmayilal's Avatar
Default Office 2000 premium on Vista Home Basic?
Can I install Office 2000 premium on a Windows Vista Home Basic PC?
Ponmayilal is offline
Old 21-06-2007, 10:22 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Office 2000 premium on Vista Home Basic?
Think so, its a MS product...should be compatable. Not sure though
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 21-06-2007, 10:44 PM   #3 (permalink)
gooby pls
Third Eye's Avatar
Yes you can install it on Vista Home
Third Eye is online now
Old 21-06-2007, 11:20 PM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Yes..U can.If it doesn't Try Compatibility MODE(Works for Many M$ Apps)
rakeshishere is offline
windows vista home premium langugage updates? legolas Software Q&A 1 16-03-2007 03:11 AM
office to home pravin4u Software Q&A 3 24-09-2005 09:34 PM
Connecting to your home PC from your office network using SS icecoolz Tutorials 3 26-04-2005 02:32 PM
Visual Basic 6 and MS Access 2000 sohummisra QnA (read only) 8 25-03-2005 10:45 AM
office assistant starting problem in office 2000 madan Software Q&A 1 13-01-2005 12:40 PM
- by Niilesh
