Old 20-06-2007, 12:47 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Vista: Problems After changing the default program instalation directory
I have created a seperate partition for program files of vista. Then i changed the default program installation directory by changing the value of "programfilesdir" in registry. Now i am facing lots of problems. The following programs are not opening
windows movie maker,windows photo galary, windows dvd maker etc.
Also there s no gadget in sidebar after doing this reg change.
Plz tell me how to deal with these problems
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga"
CadCrazy is offline
Old 23-06-2007, 01:32 AM   #2 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: Vista: Problems After changing the default program instalation directory
Any one plz
Unban Praka123
CadCrazy is offline
Old 23-06-2007, 01:39 AM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
put everything back to default
http://beingmanan.com
iMav is offline
Old 23-06-2007, 03:59 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
is ur systemrestore still working ? if it is try that option 1st !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 24-06-2007, 02:21 PM   #5 (permalink)
in search of myself
CadCrazy's Avatar
No i do t wana restore my system but i want to put all program files on another partition. In XP this trick works fine but how can i do that in vista without any problem
Unban Praka123
CadCrazy is offline
Changing My Documents Directory in Open Suse 10.2 ilugd Open Source 2 19-05-2007 04:38 PM
help in changing the default for programs pauljose Software Q&A 3 26-02-2006 05:16 PM
changing the default language in office xp mukilan Software Q&A 2 08-11-2005 01:15 AM
How to change the default installation directory. vamsi104 QnA (read only) 5 04-05-2005 05:26 PM
Default Directory Of the Updates folder ?? nicole2208 QnA (read only) 3 26-04-2005 11:46 AM
