Old 19-06-2007, 08:07 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default strange!!!!!!!!!
this is my first post here.
i asked for help in some other place.
anyways i formatted a harddisk which had linux on it made it as NTFS.
installed XP PRO on it with out partitioning. 40Gb.
when i download some thing from the net server like gtalk or some thing from download.com my pc restarts ( The procedude is follwed that is it as if i
(restarted from the start menu ).
Does not show any error message before or after the restart,
now the stranger problem is that when i try to run hl2 epsoide one it restarts the same way again ( Every single time i try to launch the game ).
I tried going through the log file and this is what it said.
oh and i do not have the folder option in the tools menu.
please help.
i do not use any antivirus. suggest some strong antivirus.
my pc config is AMD AM2 3600 Athlon 2*512 DDR2 @ 533 Geforce 6200 256MB.
I am Acrophobic, Entomophobic, Melissophobic. .
chicha is offline
Old 19-06-2007, 08:24 PM   #2 (permalink)
Is actually a real word..
Default Re: strange!!!!!!!!!
right click "my computer" select properties, advance tab, startup recovery, uncheck auto restart. now you should get an error message, (probably everyones favorite BSOD) which will help determine what the problem is. try googling the error, if that don't help podt it back here. when u installed windows did you do a quick, or full format?
Liggy is offline
Old 19-06-2007, 11:03 PM   #3 (permalink)
chicha's Avatar
thank you that seems to have stopped the restarting problem.
I did a complete fomat. but the folder option is still not available.
thank you for the tip.
chicha is offline
Old 19-06-2007, 11:16 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
r u using original / genuine XP setup CD ??
If not then it seems that ur setup cd is fabricated with malware/ virus / Trojan
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 19-06-2007, 11:25 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
SOLUTION: Folder Options not available in Tools Menu!
http://www.AskVG.com/
Vishal Gupta is offline
Strange pic ~Phenom~ Chit-Chat 5 16-06-2007 10:49 AM
Strange RAM assasin Hardware Q&A 1 01-11-2006 01:22 PM
strange!!!!really strange satbir QnA (read only) 12 11-01-2006 01:05 PM
Strange Tweak .... pirates1323 QnA (read only) 14 09-10-2005 09:38 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
