Old 19-06-2007, 05:37 PM   #1 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Boot loader Help
Hi Everyone
Just wanted to ask small question from you all. I always installed OS after activating Partitions so that Boot Managers dont cause a problem
Earlier, i used to have 98 on one partition and XP on another. I used XOSL as boot manager.
Now i have done same thing for XP and Vista. Since i made another partition active and installed Vista on it.....Vista Boot loader didnt detect XP.
I need your suggestion on some good 3rd party boot manager
On Suggestion of Vishal Gupta, i installed Vista BootPro, unfortunelt it didnt work
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 19-06-2007, 05:46 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Boot loader Help
Is ur XP installed on a partition other than C: ?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 19-06-2007, 05:50 PM   #3 (permalink)
Host4Cheap.org
Since i activate partitions to boot, when i boot Vista, XP is on Drive H and vice versa
Old 19-06-2007, 05:59 PM   #4 (permalink)
Microsoft MVP
I hv faced the same problem when I installed Vista on C: Drive and my XP was on D: Drive. Vista didnt detect XP and the Vista boot loader didnt contain entry for XP.
Then I installed Vista Boot Pro and manually added an entry for XP.
Old 19-06-2007, 06:02 PM   #5 (permalink)
Host4Cheap.org
YEah, same thing i did....downloaded Vista Boot Pro and added a entry. Now if i select that entry during boot, my PC restarts
Old 19-06-2007, 06:09 PM   #6 (permalink)
Microsoft MVP
U hv to select "Legacy OS" option and drive must be C:
Old 19-06-2007, 06:30 PM   #7 (permalink)
Host4Cheap.org
This is what i did till now. XP is installed on Partition 1 and its boot.ini has
[boot loader]
;timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Since i am on Vista, it is Drive C at the moment, on XP it is Drive H. Installed Vista Boot Pro and Edited OS Enties
Old 19-06-2007, 06:33 PM   #8 (permalink)
Microsoft MVP
Try to add a new entry for XP and choose "Legacy OS" and drive must be C:, thats what I did when I faced the same problem. Currently I don't hv Vista Boot pro installed, so can't help much.
Also try following link:
http://support.microsoft.com/kb/919529
Old 20-06-2007, 11:39 AM   #9 (permalink)
Host4Cheap.org
Yeah i did add it as Lecagy OS. LEt me try Microsoft Link
__________________________________________________ ______________________________
Hmm Getting a ERROR.. /create is there though
C:\>C:\Windows\system32\bcdedit /create {ntldr} -d "Windows XP"
The create command specified is not valid.
Run "bcdedit /?" for command line assistance.
Problem Solved with this link
http://www.pro-networks.org/forum/about92429.html
Thanks Vishal
Last edited by Sukhdeep Singh; 20-06-2007 at 11:40 AM. Reason: Automerged Doublepost
Old 20-06-2007, 02:37 PM   #10 (permalink)
Microsoft MVP
^^ Glad to see ur problem solved.
Boot Loader saiaspire Software Q&A 1 11-06-2006 02:09 PM
Boot loader ra_sriniketan Software Q&A 13 16-05-2006 06:35 PM
changing boot loader.... vipul Software Q&A 4 07-12-2005 09:04 AM
FC 3 boot loader mistake talrejaharish Open Source 3 12-02-2005 05:05 PM
Boot Loader Lost sachin_kothari Open Source 7 16-12-2004 08:24 PM
- by chris
