Old 19-06-2007, 12:04 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Regarding System Restore
I have just installed vista , no other software is intalled right now. Now i want to create restore point so that i can restore to this point later. My query is later if i restore my system to this point will restore only c : drive or all the other drives also. I am fearing it will not erase my important data on other drives.
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga"
CadCrazy is offline
Old 19-06-2007, 05:52 PM   #2 (permalink)
Anindya's Avatar
Question Re: Regarding System Restore
One more question.. If the computer or rather the os crashes then how to get the restoration done?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 20-06-2007, 12:41 AM   #3 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: Regarding System Restore
Is there anyone who can help me ?????????
Unban Praka123
CadCrazy is offline
Old 21-06-2007, 10:31 AM   #4 (permalink)
It would depend on settings in your computer related to system restore. In Win XP by default this setting is enabled by default on all drives, don't know abt Vista. If you don't want to restore a particular drive then you can disable this service for that drive in "System restore settings". By doing this you can save some disk space as well on drives other than c:
ThinkFree is offline
Old 21-06-2007, 02:49 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
SUBJECT to alloted diskspace, ur first (or any) restore point is set to delete by default only after 136 yrs. but as u keep installing and more restore points r created automatically, ur 1st and the old ones will keep getting deleted. ur data on other disks will not be lost. just MAKE SURE that u hav enabled it only for your System Disk.
if u want to keep a copy of ur brand new vista in virgin state, best to use acronis or ghost to make its copy....
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-06-2007, 01:31 AM   #6 (permalink)
in search of myself
CadCrazy's Avatar
Ghost is i think paid software. is there any free or open source software for this
Unban Praka123
CadCrazy is offline
System restore ThinkFree QnA (read only) 7 19-04-2007 09:46 AM
System Restore Goes Away.... dinesh_mettur Software Q&A 1 19-11-2006 11:47 AM
System Restore-- Big Help s18000rpm QnA (read only) 8 23-03-2006 04:44 AM
