Old 16-06-2007, 04:43 PM   #1 (permalink)
Default Nero-Error: Could not perform end of Disc-at-once - Please Help
Hi Friends
You previously helped me in BIOS this time I've nero error.
I've Nero 7 smart suit (Or whatever hell its name), previously I was able to burn Data DVDS on it, all were of UMAX (company name) DVDs,
Now I bought this 'Crux DVDs' , crux is company name by the way. & all the time, when I try to write it shows errors, after finishing the 100% writing, that 'couldnot perform end of disk at once'
I've acer 5101 Laptop, 512 MB RAM, 2 Ghz. AMD 64 , & all good, I don't use any screen saver or any other programs, while writing any thing, still it is not helping, & i've been able to write on 2 out of the 10 Crux DVDS I bought.
I know there are a lot experts here, plz. give me some solution,
I know you'll help, so thanks in advance.
Let me include the log file of the error....
The Oddman
WTMAC
1A20-020E-0000-1349-1210-6697*
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 2:03:20 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 5:33:44 PM
Nero version: 6.3.1.26 (Nero Express)
Recorder: <Slimtype DVDRW SSM-8515S>Version: GRS6 - HA 0 TA 1 - 6.3.1.26
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <Slimtype DVDRW SSM-8515S >Version: GRS6 - HA 0 TA 1 - 6.3.1.26
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK6034GAX atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Slimtype DVDRW SSM-8515S atapi Port 0 ID 1 DMA: On
=== CDRom-Device-Map ===
Slimtype DVDRW SSM-8515S E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 66060288 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 446MB (456808kB)
Free physical memory: 88MB (91000kB)
Memory in use : 80 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.6.2007
ISO compilation
6:30:54 AM #1 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
6:30:54 AM #2 Text 0 File Reader.cpp, Line 126
Reader running
6:30:54 AM #3 Text 0 File Writer.cpp, Line 124
Writer Slimtype DVDRW SSM-8515S running
6:30:54 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
6:30:54 AM #5 Text 0 File Burncd.cpp, Line 3152
Turn on Disc-at-once, using DVD media
6:30:55 AM #6 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2288383 (508:31.58, 4469MB)
6:30:55 AM #7 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
6:30:55 AM #8 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: Slimtype DVDRW SSM-8515S, Media type: DVD+R
Disc Manufacturer ID: Plasmon1, Media Type ID: C01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
6:30:55 AM #9 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
6:30:55 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2288384 (2288384) = #2288384/508:31.59
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2288384 blocks [Slimtype DVDRW SSM-8515S ]
6:30:55 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [Slimtype DVDRW SSM-8515S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4686610432, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2288384 | lead-out | 1 | 0x00 | 0x41
6:30:55 AM #12 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
6:30:55 AM #13 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
6:30:55 AM #14 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
6:30:55 AM #15 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 2.4x (3,324 KB/s)
6:30:56 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:30:56 AM #17 Text 0 File Cdrdrv.cpp, Line 8228
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Media type ID: C01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 50 6C 61 73 6D - 6F 6E 31 43 30 31 00 38 ...Plasmon1C01.8
23 54 37 15 02 52 6C 02 - B4 63 15 15 0B 0A 08 08 #T7..Rl..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
6:30:56 AM #18 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 23:47,478 (1427478ms) -> OK
6:30:56 AM #19 Text 0 File DVDPlusRW.cpp, Line 628
Start write address at LBA 0
DVD high compatibility mode: Yes
6:53:11 AM #20 Text 0 File WriterStatus.cpp, Line 115
<Slimtype DVDRW SSM-8515S > start writing Lead-Out at LBA 2288384 (22EB00h), lenght 0 blocks
6:53:12 AM #21 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
6:53:39 AM #22 SCSI -1176 File Cdrdrv.cpp, Line 1191
SCSI Exec, HA 0, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x03
6:53:39 AM #23 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
6:53:39 AM #24 CDR -1176 File ThreadedTransferInterface.cpp, Line 1708
Session fixation error
6:53:39 AM #25 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1708
6:54:17 AM #26 Phase 127 File dlgbrnst.cpp, Line 1855
Generating DVD high compatibility borders
6:55:26 AM #27 Text 0 File dlgbrnst.cpp, Line 1713
6:55:26 AM #28 Phase 129 File dlgbrnst.cpp, Line 1855
Generating DVD borders completed successfully
6:55:26 AM #29 Text 0 File dlgbrnst.cpp, Line 1713
6:55:26 AM #30 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 1:05:10 PM
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 4:59:44 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Billyips339 is offline
Old 16-06-2007, 09:01 PM   #2 (permalink)
Is actually a real word..
Default Re: Nero-Error: Could not perform end of Disc-at-once - Please Help
sounds like low memory... check you email buddy.
Liggy is offline
Old 16-06-2007, 09:26 PM   #3 (permalink)
Anindya's Avatar
why dont u try with any dvd from other companies and see what happens?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 16-06-2007, 10:18 PM   #4 (permalink)
try riting less than 4.7gb (say 4gb only ) . i see that ur physical mem is very low.dont load too many programs in the background . does this happen with sony or moserbaer discs also ? ( the 2 u mentioned appear to be cheepos) . and can u rite in track at once mode successfully?
sagargv is offline
disc reading error yash2006 Hardware Q&A 4 07-10-2006 10:17 AM
Nero 7 burning error.....please HELP!!! pirates1323 Software Q&A 2 02-04-2006 06:30 PM
Nero Burning ROM error Gaurav Software Q&A 8 22-08-2005 04:54 PM
Please help!!!!!!!!! -Could not perform end of disc at once libinbenny QnA (read only) 4 05-03-2005 07:23 PM
