Old 16-06-2007, 01:31 PM   #1 (permalink)
Default Knowing target locations of installed applications
Hi friends! Is there any way to know all the target locations of files of the installed applications? Like when a software is installed , where all it writes its files , including the registry. Is there any software or any method to monitor and retrieve ?
Thanks in advance.
Tamilvendan
tamilvendan is offline
Old 16-06-2007, 01:35 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Knowing target locations of installed applications
well...right click on main file(may be on desktop..or start menu)--->>properties
There is the location of that file.All program files are stored there.For registry..U need to have some knowledge of registry.
ravi_9793 is offline
Old 16-06-2007, 02:18 PM   #3 (permalink)
Hi thanks for your reply but that is not sufficient. I hope no application writes its all files in just one location. Like it writes in program files, complus applications, common files, application data of ( all users, default users, administrator) and in system32 of windows and may be in many other places as well. This u can know, whenever we uninstall any application, there are many files left in many places. This whole bundle of locations i want to know. Is there any method or program which can trace all this?
Tamilvendan
Old 16-06-2007, 04:34 PM   #4 (permalink)
hullap's Avatar
You can even keep your mouse on the shortcut
hullap is offline
Old 16-06-2007, 04:37 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
There are installation monitors available which you have to run while installing an application. It will keep track of all the locations where the files went and all those changes made to the registry are logged. You can make a log file and later uninstall it directly from this log file.
Nokia N86 8MP
Lucky_star is offline
Old 16-06-2007, 06:45 PM   #6 (permalink)
Hi Lucky star! That was an excellent information i was looking for. Thanks for that.I even downloaded one such tool. In the same way can we track down the file locations of already installed applications?
Tamilvendan
Old 16-06-2007, 10:03 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
I don't think you can figure out the locations of already installed applications.
Nokia N86 8MP
Old 17-06-2007, 01:14 AM   #8 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
http://www.microsoft.com/technet/sys...k/Filemon.mspx
This utility from Sysinternals can monitor while installation all the locations a installer writes to.
For finding locations of already installed softwares try viewing files such as install.log or any other installation log file in software folder. It can give a fair idea about locations a software got installed to.
navjotjsingh is offline
Knowing more than one programming language rajesh_nk22 Programming 1 23-05-2007 02:09 PM
Knowing Who changed data in MS SQL SERVEr rajesh_nk22 Software Q&A 1 30-06-2006 12:00 PM
any software for knowing computer usage shreyadr Software Q&A 11 09-06-2005 03:27 PM
Knowing Knoppix Free Book tuXian Open Source 8 04-01-2005 08:45 AM
Anybody is knowing performence of riva tuner....Help me? bhalchandra Software Q&A 1 07-11-2004 10:36 PM
- by chris
