Old 15-06-2007, 07:25 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Wierd Internet Problem
for the past few days iv been facing this wierd problem my isp is sify:
now the problem is that after i shut down pc for a few hours and then turn it on again and try to connect to the net the dialler logs in but no page is displayed in any browser
now im usually in vista now to rectify this problem for some reason i need to go into xp disable my lan for some time and then enable the lan again now when i login and browse everything seems fine
http://beingmanan.com
iMav is offline
Old 16-06-2007, 06:15 AM   #2 (permalink)
eagle_y2j's Avatar
Default Re: Wierd Internet Problem
seems there is some DNS resolution problem to see if DNS resolution is working you can see if the DNS server you are configured to query knows what it’s talking about. Using the NSLOOKUP command shows this information
Registered LINUX USER #438929
eagle_y2j is offline
Wierd Internet Problem kirangp Software Q&A 3 22-03-2007 07:45 PM
a really wierd problem vikram Software Q&A 2 15-05-2006 10:49 AM
Wierd Internet Connection Sharing problem! SmoothCriminal Software Q&A 5 09-02-2006 01:58 AM
Wierd problem with my net drvarunmehta QnA (read only) 4 04-02-2005 11:23 PM
- by chris
