Old 15-06-2007, 02:38 AM   #1 (permalink)
free world from money
Projjwal's Avatar
Default Cheek ur system speed correctly...
cheeking speed of any system is a very hard job.If i asked this question that which system faster between two close configured system it's really tough. But from super_pi program u can calculate the real speed of ur system.
I share the file for u.
this is the link http://h1.ripway.com/projjwal/super_pi.zip
cheek ur system using super_pi then write the result of the analysis as post (result on pi_rec.txt file. )cheek upto 2M thats enough.
Projjwal is offline
Old 15-06-2007, 10:02 AM   #2 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
Default Re: Cheek ur system speed correctly...
i remember reading about this so it must already be posted here !!!
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 15-06-2007, 12:19 PM   #3 (permalink)
hullap's Avatar
000h 1m 31s .Is that good?
hullap is offline
Old 15-06-2007, 04:25 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
My E6600 without OC running at 1.60 GHz with speed step enabled does it in 51 seconds...
Without speed step and without OC and running at 2.4 GHz does it in 48s / 47s
Never tried it with OC !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-06-2007, 11:19 PM   #5 (permalink)
Projjwal's Avatar
My result is 1m 21s
System Info:2400+ AMD AthlonXP,512 MB ram without OC.
Projjwal is offline
Old 16-06-2007, 12:20 AM   #6 (permalink)
Rebooting
Guess POST how many Digit or PI u have calculated ??
as Reslut will change a LOT with compairing with 2Million and 16k
Anyway, Here is my result again with 1m
System Spec
E6600 @ 2.75 GHz (OC)
Dual Channel 2 GB 667Mhz DDR-II running @ 766MHz (OC)
rebooting
ChotoCheeta.com
Old 16-06-2007, 12:33 AM   #7 (permalink)
Projjwal's Avatar
WOW.......WOW..........WOW..........Great result.....
Projjwal is offline
Old 16-06-2007, 12:37 AM   #8 (permalink)
Rebooting
How may u have calculated ?? Post ur result with 1m as i see 1m or 2m is the most people do, and to test stability when oc people run up to 32m
rebooting
ChotoCheeta.com
Old 16-06-2007, 12:44 AM   #9 (permalink)
clmlbx's Avatar
1m 17s For 2 Million
Pc Specs :-
E4300
1 Gb Ddr2 667mhz
Nothing Overclocked
How Is Mine ?
1 MILLION == JUST 34 SECONDS
clmlbx is online now
Old 16-06-2007, 12:47 AM   #10 (permalink)
Rebooting
Pc Specs :-
E4300
1 Gb Ddr2 667mhz
Nothing Overclocked
Now That's Some thing Cooool... as My C2D E6600 with 2GB DDR-II 667MHz with OC takes 1m 10s i guess !!!
How Is Mine ?
Quite unbilivible as never seen such result with E4300
rebooting
ChotoCheeta.com
Last edited by Choto Cheeta; 16-06-2007 at 12:47 AM. Reason: Automerged Doublepost
Old 16-06-2007, 12:50 AM   #11 (permalink)
Projjwal's Avatar
I already post my result for 1M
the result is,
1m 21s
System Info:2400+ AMD AthlonXP,512 MB DDR RAM without OC.
Projjwal is offline
Old 16-06-2007, 12:57 AM   #12 (permalink)
clmlbx's Avatar
Runned Next Ime To Get The Screenshot..
So The Result For 1 Million = 33 Sec
Here Is The Screenshot :-
Old 16-06-2007, 01:01 AM   #13 (permalink)
Projjwal's Avatar
@clmlbx what is ur system configeration??.....
Projjwal is offline
Old 16-06-2007, 01:04 AM   #14 (permalink)
clmlbx's Avatar
Talking Re: Cheek ur system speed correctly...
My Config :-
E4300
1gb Ddr2 667 Mhz
Old 16-06-2007, 01:22 AM   #15 (permalink)
Rebooting
Quite Unbilivble really amezing to see E4300 without OC putting that result !!!
rebooting
ChotoCheeta.com
Tokyo boffins crack internet speed record - reached 7.67Gbps speed! Kiran.dks Technology News 35 19-10-2007 01:16 AM
If Increase the RAM Then the System speed will increase muralikrishnan QnA (read only) 9 23-09-2005 03:52 PM
Printing not correctly kumarn_2004 QnA (read only) 4 04-07-2005 11:22 PM
cpu not correctly recognized bikramjitkar CPU / Motherboards 10 26-02-2005 08:42 PM
- by chris
