Old 15-06-2007, 12:24 AM   #1 (permalink)
Question Start->Run ;Taskmanager;Registry Editing Disabled due to Worm Attack -- HELP
Few days ago i had a worm attack which activated on running the Y!Mesngr .
  1. As a consequence the Run option ;Taskmanager and Registry editing of my Win XP has been disabled.
  2. Whenever i Ctrl+Alt+Del mesg displayed is "Task Manager has been disabled by your administrator";while the user is and still being showwn as a Computer admonistrator in Control Panel->User Accounts.
  3. Similar for regedit.
  4. All other activities are apparent normal
What i did was
1>scanned using NOD32 and Avast which removed the worm.
2>created another user .this second user has no problems Run working Registry editing available
Pl
HELP
  • .How to get back theStart->Run option?
  • ..How to get back the Taskmanager option?
  • ...How to get back the Registry Editing right option?
.Also whats the WinXP Registry Hack for enabling/disabling Start->Run
debashiskayal is offline
Old 15-06-2007, 12:43 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Start->Run ;Taskmanager;Registry Editing Disabled due to Worm Attack -- HELP
Pls visit following threads:
SOLUTION: Folder Options not available in Tools Menu!
TUTORIAL: All Kinds of Restrictions for Windows XP/2003
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 17-06-2007, 12:12 AM   #3 (permalink)
Question Re: Start->Run ;Taskmanager;Registry Editing Disabled due to Worm Attack -- HELP
hey Vishal thanx ..though after posting i had gone through those threads ..still thanx
But wat i didnt find in any of those tutorials or any where till now is
Registry hack to enable/disable Run in the Start
Please
Old 17-06-2007, 12:32 AM   #4 (permalink)
Microsoft MVP
Open regedit and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In right-side pane look for a DWORD value NoRun. If its there, delete it. If its not there, then create it and set its value to 0. Reboot/log off to see the changes.
Old 17-06-2007, 02:28 AM   #5 (permalink)
hey
vishal thanx again man ...but i think i will hav to bother u again....
i dunno wat the reason of the problem is ..but
My system clock (the rtaskbar clock) seems to be not working properly ..meaning it is running late ...
even if i had set it to the current time again and again
its lagging
Also many times while booting its showing that the sys date n time is not set and i hav to set it evwery time through Setup.
Old 17-06-2007, 02:41 AM   #6 (permalink)
Microsoft MVP
Its happening bcoz of the weak CMOS battery.
Open ur cabinet and u'll see a small coin size battery attached in the motherboard. Remove it and insert a new battery. U can get the battery from market within 20-30 Rs.
Old 17-06-2007, 02:48 AM   #7 (permalink)
hey thank u but r u sure .. will try sure
registry disabled iMav Software Q&A 17 02-02-2007 06:58 PM
Registry Disabled !!!!! Rishabh_sharma1990 Software Q&A 5 18-01-2007 12:33 PM
registry editior disabled thadhanihemant QnA (read only) 14 04-09-2006 03:36 PM
Registry Editor disabled...help!!! linardni QnA (read only) 2 24-06-2006 03:14 PM
unable to start taskmanager drsethi QnA (read only) 5 06-10-2005 10:25 PM
- by chris
