Old 14-06-2007, 03:36 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default My system has recovered from a serious Error
booted my windows after a long time, and just after running it the system restarted without any BSOD juts a blank screen for 2 sec then restart.
after booting up i got the following msg
REST INFO COMMING IN SHORT WHILE
gary4gar is offline
Old 14-06-2007, 05:27 PM   #2 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile Re: My system has recovered from a serious Error
try to run ur system in safe mode and then check the log file for error
can also try to run system in (most recent setting that work) mode
someone plz correct if i am wrong
saurabh kakkar is offline
Old 14-06-2007, 11:44 PM   #3 (permalink)
Default Re: My system has recovered from a serious Error
should we also recover the error log files ?
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 17-06-2007, 11:26 AM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
Dialog Box 2
Dialog Box 3
gary4gar is offline
System recovered from serious error ?? sridatta Software Q&A 7 07-12-2006 04:52 PM
Unused space on hard drives recovered? quad master Hardware Q&A 2 08-12-2005 11:22 PM
ISASS.EXE System Error...? raval_manoj Software Q&A 8 25-11-2005 11:34 PM
- by chris
