Old 12-06-2007, 09:57 AM   #1 (permalink)
Default IE Title Bar Problem
Well I am using IE explorer 7 on an original XP SP2....the system is performing fine except for the fact that the Title Bar shows " Internet Explorer- Hacked By Godzilla". I checked the system 4 spywares and adwares but culdnt find ne.
Can this be rectified??? Plz guide me////
iammrcool is offline
Old 12-06-2007, 10:30 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: IE Title Bar Problem
un-install the IE 7, download it from Microsoft.com, http://www.microsoft.com/windows/dow.../getitnow.mspx
now try to install again
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-06-2007, 10:34 AM   #3 (permalink)
I think there may b a much simper way out...mayb tweaking sm registry entries...can smbde help?
Old 12-06-2007, 10:45 AM   #4 (permalink)
Rebooting
OK, it depends, as to u may be Eiditng registyry seems easy, anyway, here is how u may do it,
Navigate to, HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
if u see any key as , Window Title then Delete that it should solve the Issue....
but it seems that ur IE7 installation source didnt come directly from Microsoft, so it may have security issue, thats why I suggested to un-install and then Re-install with Microsoft Download !!!
rebooting
ChotoCheeta.com
Old 12-06-2007, 10:59 AM   #5 (permalink)
Hey thanx bro....got it....
Serious Problem Need help (EXPLORER) max_demon Software Q&A 8 08-05-2007 11:36 PM
problem with explorer Samish Tutorials 2 06-11-2006 08:26 PM
problem with explorer njm Software Q&A 2 12-09-2006 01:37 PM
FCB IE - Title hack problem ramprasad QnA (read only) 3 06-09-2006 04:16 PM
Explorer Problem !!! dreams Software Q&A 6 24-12-2005 07:42 AM
- by chris
