Old 11-06-2007, 04:14 PM   #1 (permalink)
ComputerUser's Avatar
Default Nero 7 Premium problem
I installed the trial version of Nero 7 Premium. After uninstalling it, when I used a pendisk, it showed the drive letter to be M:, whereas before it was L:. Therefore now the pendisk is not drive L: as it should be.Please help.
ComputerUser is offline
Old 11-06-2007, 04:23 PM   #2 (permalink)
CA50's Avatar
Default Re: Nero 7 Premium problem
U can change the drive letter. Follow the give steps:
Right click on "MY COMPUTER"
Go to "MANAGE"
Click on " Disk Managment"
Insert ur pendrive , it will be on the window, rt click on it & select "change driveletter..."
GO ON CHANGE IT...
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
nero 7.0 premium clmlbx Software Q&A 6 01-05-2007 08:13 AM
problem with nero 7 premium gau_pppu Software Q&A 4 31-03-2007 10:33 PM
Nero Ultra Vs Nero Premium.. shyamno Software Q&A 8 31-01-2007 07:11 PM
Problems with Nero 7 Premium kguragain Software Q&A 3 28-12-2005 10:36 AM
Nero Premium 7.0.1.4 rajat22 Software Q&A 6 22-12-2005 02:59 AM
- by chris
