Old 11-06-2007, 11:33 PM   #1 (permalink)
free world from money
Projjwal's Avatar
Default Problem with DOS.
Hi, friends
I don't know is it right place or not for my post.
I create a program which generate a batch file for LAME . to convert normal MP3 to VBR(Veriable Bit Rate).In normal case it worked fine but for the non-8dot3 file means filename with space ,'-' etc it's not working .So, i want a thing which can convert "non-8dot3" to "short name".
e.g: Suppose link is c:\New songs\track1-goodsong.mp3 to
c:\NEWSON~1\TRACK1~1.MP3.
I use c#.NET .
I already googled about it .
Pls help
I already solve de problem.......So,Moderator Pls close this Thread.
Projjwal is offline
Old 11-06-2007, 11:59 PM   #2 (permalink)
sachin_kothari's Avatar
Default Re: Problem with DOS.
if u have solved the problem then also post the solution, so that others who face similar problems know a way to get out of it.
sachin_kothari is offline
Old 18-06-2007, 10:24 PM   #3 (permalink)
Projjwal's Avatar
Just write the path between "...(Between double inverted comma)
e.g:
"c:\New songs\track1-goodsong.mp3"
It's a very eassy solution...
Projjwal is offline
Old 19-06-2007, 02:00 AM   #4 (permalink)
ashfame's Avatar
Can i hav a list of all da commands of dos under one roof?
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by chris
