Old 10-06-2007, 09:14 AM   #1 (permalink)
Default shutdown problem?????????
i cant shutdown or restart my pc while presing on start button
i cant shutdown using shurdown -s -t 00 it also doen't work
i cant change admin a/c [acess is denied]
i cant open gpedit.msc group policy
is there any way i can restore it....
i do have any restore point in my computer
kiranbajpe is offline
Old 10-06-2007, 11:41 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: shutdown problem?????????
Possible you may have Virus Infection... Please use any good AVS or use one online scanner, like http://www.kaspersky.com/virusscanner to see if u have a Virus on the PC or not... I suggest u download Kaspersky AntiVirus Trial, install it, and run a scann !!! Make sure when u try to scan ur PC for Virus, u turn off the System Restore .... Also get ur self, Spybot SnD run a scan with it to make sure no spyware....
Make sure U have the Lastest Service Pack installed for ur OS and latest update Patches !!!
Once u made sure system is Virus/Spyware free, then go to start, and then run, command, sfc /scannow, u would need Windows Installation source for that !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
problem in shutdown gau_pppu Software Q&A 8 17-04-2007 10:23 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
Shutdown Problem choudang QnA (read only) 6 04-12-2005 11:54 PM
Shutdown Problem muralibalan QnA (read only) 1 03-09-2004 06:39 PM
shutdown problem atul QnA (read only) 3 31-08-2004 12:41 AM
- by chris
