Old 09-06-2007, 07:02 PM   #1 (permalink)
mr_fanatic's Avatar
Exclamation Help: CODE.EXE ?
Greetings,
After downloading and installing the latest virus definitions from http://definitions.symantec.com/defs/ it found a W32 Brontok virus on all the system hard disk drives. After successfully deleting the virus, i format only the C: Drive and reinstall a fresh copy of Windows XP Professional. After the installation is done, i can open c: drive as normal, but cannot open the other drives giving me an error message "cannot find copy.exe" as shown on the screen shot below:
http://img518.imageshack.us/img518/7...eenshotvw6.gif
the other drives other than c: can though be open by using the Right Click > Open/Explore command. This is really annoying and it would be greatly appreciated if someone had already experienced this kind of problem or have any ideas.
Thanks.
mr_fanatic is offline
Old 09-06-2007, 07:10 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Help: CODE.EXE ?
Look for autorun file in drive by exploring it ,if any Remove the hidden autorun.inf file frm each drive and try...
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 12-06-2007, 01:31 PM   #3 (permalink)
mr_fanatic's Avatar
I can't find autorun.inf on C: drive and also on all the other drives
Old 12-06-2007, 05:06 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Smile Re: Help: CODE.EXE ?
^^^set to - check show hidden file and uncheck do not show protected file , From folder option
zyberboy is offline
Old 12-06-2007, 05:43 PM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
^^ yes, try to show hidden files & then search for autorun file
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is online now
Old 13-06-2007, 05:58 PM   #6 (permalink)
mr_fanatic's Avatar
i've done that always. but stilll no luck (
Old 13-06-2007, 07:44 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open regedit and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\
Now delete the key MountPoints2.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Need a code... Ron QnA (read only) 4 17-12-2006 01:42 AM
Help with Code Mr.Cool QnA (read only) 10 09-12-2006 02:37 PM
what is this code all about?? arunks QnA (read only) 9 24-10-2006 10:27 PM
- by chris
