Old 08-06-2007, 03:47 AM   #1 (permalink)
Default winXP & vista, format xp, issue.
Hi,
I have winXP and installed a fresh copy of vista on another partition. Now, I wanted to format windows XP and install Ubuntu linux in it. Can it be easily done? I mean, will vista run properly after formatting XP?
thks,
legolas.
legolas is offline
Old 08-06-2007, 03:59 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: winXP & vista, format xp, issue.
no, u have to boot with Vista DVD to repair the Vista Boot loaders... and its pretty simple and automated... !!
Nothing is simple... may be a thing is simple for simple for u, but it can be very though for me !!!
but I think once when u install Ubuntu, Vista Boot loader will be deleted, and u may have to repair it !!! and possible may be while repairing the Vista Boot loader u may not be able to boot using GRUB !!!
anyway, Question should be in Open Source section... !!!
P.S.
after u repair Vista, u may lose Ubuntu GRUB loader Refer here, to repair Ubuntu, GRUB loader http://ubuntuforums.org/showthread.php?t=224351
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-06-2007, 04:10 AM   #3 (permalink)
Thanks Cheeta,
my question was about the problems with formatting XP. So, i guess this should be in QnA rather than Open Source.
so in case i plan to have only vista, then after formatting XP, i just have to use the vista DVD and repair the bootloader... right?
legolas
legolas is offline
Old 08-06-2007, 09:47 AM   #4 (permalink)
ya . sort of . . after u format xp , u need not do the vista repair . vista controls the multiboot , so u format xp , u just loose xp , vista will be fine . xp will still be in the boot menu , but if u choose it , some error comes or ur system restarts . but vista will be in the boot menu and will be fine .
the prob is abt linux , u remove xp and install linux then chances are that u might loose vista . u have to use the vista boot dvd and repair vista boot loader. BUT , during this , chato cheeta is suggesting that after u repair vista boot loader , ur linux may not be detected by vista boot loader .and hence GRUB , it might detect vista or vice versa . if u got good luck , it'll be vice versa .
so its damn simple if u just want to remove xp , but not that simple if u want linux . ( it may be if grub or vista boot loader recognizes the other os ).
sagargv is offline
Old 08-06-2007, 12:02 PM   #5 (permalink)
Rebooting
Nope... Vista do controls the Boot loader but that Boot loader will be in C drive !!! as u format Windows XP u will lose the C drive along with that Boot loader therefore u will neeed to repair the Vista boot loader !!!
rebooting
ChotoCheeta.com
Old 08-06-2007, 12:50 PM   #6 (permalink)
ok . i didnt know that . why didnt they keep the boot.ini file .
sagargv is offline
Old 09-06-2007, 01:50 AM   #7 (permalink)
Hi, here they have an excellent tutorial,
http://apcmag.com/5046/how_to_dual_b...nstalled_first
so, i dont think the second issue is a problem. Thanks a lot anyways. I hope i can fix vista after formatting XP.
Thanks again,
legolas.
Ok, I formatted XP but couldnt repair Vista. It says "Lolo" when starting... Can any1 help me with this?
thanks,
legolas.
legolas is offline
Old 09-06-2007, 01:59 AM   #8 (permalink)
Rebooting
LOLO ??
rebooting
ChotoCheeta.com
Old 09-06-2007, 02:03 AM   #9 (permalink)
If i remove a Windows Vista that is in C: Drive with NTFS Partition, so it will also format my Windows XP. No will i don't like a WIndows XP. If i have a Vista .LOL
Originally Posted by Choto Cheeta
LOLO ??
PIRATED VERSION.!!!.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 09-06-2007, 02:08 AM   #10 (permalink)
I got it along with my laptop, now why wud it say "pirated version"???
legolas
legolas is offline
Old 09-06-2007, 02:12 AM   #11 (permalink)
Rebooting
May be version problem, as u may be allowed to install Home Basic or such and u may have used any othert key to install any other version ??
check if that's not the reason...
and funny Nick name LOLO = Pirated Version :lol
rebooting
ChotoCheeta.com
Old 09-06-2007, 10:27 AM   #12 (permalink)
yes possible . 2 options left : , download pirated version and correct it. or reinstall vista as well .
@legolas , now ur link clearly shows how to do vista & ubuntu dual boot . now , how do u recover vista . try to install ubuntu , if it can recognise vista and u need not use vista boot loader , its done , if not , well , lets see later....
sagargv is offline
Old 09-06-2007, 10:34 AM   #13 (permalink)
i dont think so.
abhijangda is offline
Old 09-06-2007, 11:10 AM   #14 (permalink)
and in the same site , i saw a xp vista dual boot guide . if u have xp on C and install vista on D , wont vista automatically detect xp ? why all the confusion given there ?( i agree that reverse is not that simple )
sagargv is offline
Old 12-06-2007, 03:15 AM   #15 (permalink)
hi,
I reinstalled vista and ubuntu! but now everything is fine...
thks,
legolas.
legolas is offline
HELP: Vista firewall issue Faun Software Q&A 7 23-03-2007 01:14 PM
how to format lagre drive with fat32 in winxp DukeNukem Software Q&A 15 24-09-2006 02:54 PM
Request: How to Format WinXP Tutorial prathew Software Q&A 7 27-08-2005 04:52 PM
WinXP format new hard disk SGS Software Q&A 3 31-07-2005 01:27 PM
WinXP Pro SP! - Compatibility issue Nariman Software Q&A 5 05-12-2004 11:01 PM
- by chris
