Originally Posted by dabster
@HIM007: 1. disable the preprocessing filter(in ffdshow), while you play with Media player classic. ffdshow is used when u install klite.
or Just use "VLC player" it uses minimum CPU time for playing Movie, that will be much better for yr PC.
2. yes, you need to convert them to DVD format to play(if the DVD player is not Divx compliant). you can use flaskMPEG for doing that.
This answers your question, Rest I dont know what crap is being discussed here.
IS VLC PLAYER run AVI, 3gp format? How to disable the ffdshow & what is flaskmpeg?
Originally Posted by bhushan05d251
Or try to Install DivX from here.
It plays mpeg4 format files like avi (DivX and XviD).
Before installing DivX remove or disable your codec pack. And check whether your DVD player supports DivX (or MPEG4) format. If yes then burn those files directly on DVD using "Create Data DVD" from Nero. No need to convert it into DVD (MPEG2) format.
I have installed the DIVx player, in some avi files voice is there but for some it says plz download the codec to play this file, I dnt know why ?
It is also not playing the 3gp format.
