Re: Destop Location!
If you are using NT based windows (Windows NT, XP, etc) and have NTFS partitions instead of FAT32, you can do it... Log in with admin priviledges. Right click on C drive, go to properties. Go to security tab and set permission for individuals to access C drive (read, write, etc)... You can also modify the setting for the root drive only or for all subfolders...
Arun
