Old 05-06-2007, 06:58 AM   #1 (permalink)
Default Need Help: Plz analyze this Hijackthis log
Hi,
Plz analyze this log generated by hijackthis 2 beta.
I think I have a few spywares and a virus may be.
etrust generated this result. spybot and adware showed none.
config
AMD Athlon XP 1800+
MSI KT4-V mobo
Transcend 1GB DDR400
5200/128MB AGP 8X
Seagate 160GB barracuda
Samsung 80 GB
Lite-ON 20X dvd writer
Samsung 17" 753s
Win XP + SP2
Kaspersky antivirus and antihacker
spybot 1.4
adware Build1.06r1
installed yesterday
spywareblster
spywareguard
etrust spyware (only scans, does not repairs)
Other problem is that when I copy ne data in ne of my or friends' usb flash drives i can copy at max 550 KBps on my PC, while for same purpose I get 3 MBps on same drives on other PCs.
But I can read at normal speeds.
Hijackthis ver 2 beta log
Logfile of Trend Micro HijackThis v2.0.0 (BETA)
Scan saved at 06:36:28, on 05/06/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe
C:\Program Files\IVT Corporation\BlueSoleil\BTNtService.exe
C:\WINDOWS\System32\nvsvc32.exe
C:\WINDOWS\System32\HPZipm12.exe
C:\Program Files\HHVcdV7Sys\VC7SecS.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\HHVcdV7Sys\VC7Play.exe
C:\Program Files\CA\eTrust Internet Security Suite\caissdt.exe
C:\Program Files\CA\eTrust Internet Security Suite\eTrust PestPatrol Anti-Spyware\PPActiveDetection.exe
C:\Program Files\Clock Tray Skins\ClockTraySkins.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\iolo\System Mechanic Professional 6\SMSystemAnalyzer.exe
C:\Program Files\EnhanceKeyboard\kb_2k.exe
C:\Program Files\Kaspersky Lab\Kaspersky Anti-Hacker\KAVPF.exe
C:\Program Files\VisualTaskTips\VisualTaskTips.exe
C:\Program Files\KatMouse\KatMouse.exe
C:\Program Files\SpywareGuard\sgmain.exe
C:\Program Files\Netropa\Multimedia Keyboard\TrayMon.exe
C:\Program Files\Netropa\Onscreen Display\OSD.exe
C:\Program Files\SpywareGuard\sgbhp.exe
E:\totalcmd\TOTALCMD.EXE
C:\WINDOWS\system32\wuauclt.exe
C:\DOCUME~1\Ashish\LOCALS~1\Temp\_tc\HiJackThis_v2 .exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
R3 - URLSearchHook: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O2 - BHO: (no name) - {343FA0FE-26EE-4BE9-980C-24F5E2D69FE3} - C:\WINDOWS\System32\vbgjbejh.dll (file missing)
O2 - BHO: BitComet ClickCapture - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - D:\Program Files\BitComet\tools\BitCometBHO_1.1.3.28.dll
O2 - BHO: SpywareGuard Download Protection - {4A368E80-174F-4872-96B5-0B27DDD11DB2} - C:\Program Files\SpywareGuard\dlprotect.dll
O2 - BHO: Internet Security Class - {A75E294E-C047-4D29-B07E-37B792881BEF} - C:\Windows\SecureWin31.dll
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\System32\NeroCheck.exe
O4 - HKLM\..\Run: [MULTIMEDIA KEYBOARD] C:\Program Files\Netropa\Multimedia Keyboard\MMKeybd.exe
O4 - HKLM\..\Run: [KAVPersonal50] "C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus Personal\kav.exe" /minimize
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [Secure] C:\WINDOWS\WindowsUpdates.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [VC7Player] C:\Program Files\HHVcdV7Sys\VC7Play.exe
O4 - HKLM\..\Run: [CaISSDT] "C:\Program Files\CA\eTrust Internet Security Suite\caissdt.exe"
O4 - HKLM\..\Run: [eTrustPPAP] "C:\Program Files\CA\eTrust Internet Security Suite\eTrust PestPatrol Anti-Spyware\PPActiveDetection.exe"
O4 - HKLM\..\RunServices: [Msn Messenger] pplzmex.exe
O4 - HKCU\..\Run: [SkinClock] C:\Program Files\Clock Tray Skins\ClockTraySkins.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [SMSystemAnalyzer] "C:\Program Files\iolo\System Mechanic Professional 6\SMSystemAnalyzer.exe"
O4 - Startup: Shortcut to VisualTaskTips.exe.lnk = C:\Program Files\VisualTaskTips\VisualTaskTips.exe
O4 - Startup: KatMouse.lnk = C:\Program Files\KatMouse\KatMouse.exe
O4 - Startup: SpywareGuard.lnk = C:\Program Files\SpywareGuard\sgmain.exe
O4 - Global Startup: enhanced keyboard driver.lnk = C:\Program Files\EnhanceKeyboard\kb_2k.exe
O4 - Global Startup: Kaspersky Anti-Hacker (2).lnk = C:\Program Files\Kaspersky Lab\Kaspersky Anti-Hacker\KAVPF.exe
O8 - Extra context menu item: &D&ownload &with BitComet - res://D:\Program Files\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: &D&ownload all video with BitComet - res://D:\Program Files\BitComet\BitComet.exe/AddVideo.htm
O8 - Extra context menu item: &D&ownload all with BitComet - res://D:\Program Files\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: &WordWeb... - res://C:\WINDOWS\System32\wweb32.dll/lookup.html
O8 - Extra context menu item: Append to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: (no name) - {85e1f530-48f4-11d9-9629-08ff2ffc9f67} - (no file)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe (file missing)
O12 - Plugin for .pdf: C:\Program Files\Internet Explorer\PLUGINS\nppdf32.dll
O16 - DPF: {597F5878-51C6-11D3-B2DF-00C04F79E868} (MPIT List Class) - file://C:\Program Files\Microsoft Interactive Training\O10C\msbslist.cab
O16 - DPF: {6F74F92E-8DD8-4DDE-8FB8-CBB882A68048} (Microsoft Office XP Professional Step by Step Interactive) - file://C:\Program Files\Microsoft Interactive Training\O10C\mitm0026.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS1\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS2\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS3\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS4\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS5\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS6\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS7\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS8\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O17 - HKLM\System\CS9\Services\Tcpip\..\{3D5EAB1D-504F-4628-A103-BBB6C3FF8D29}: NameServer = 172.16.1.1
O20 - Winlogon Notify: nnnkkhe - nnnkkhe.dll (file missing)
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: BlueSoleil Hid Service - Unknown owner - C:\Program Files\IVT Corporation\BlueSoleil\BTNtService.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: kavsvc - Kaspersky Lab - C:\Program Files\Kaspersky Lab\Kaspersky Anti-Virus Personal\kavsvc.exe
O23 - Service: Macromedia Licensing Service - Macromedia - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: Net Logon Manager - Unknown owner - C:\WINDOWS\system32\spoolvc.exe (file missing)
O23 - Service: Netropa NHK Server (nhksrv) - Unknown owner - C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe
O23 - Service: Virtual CD v7 Management Service (VC7SecS) - H+H Software GmbH - C:\Program Files\HHVcdV7Sys\VC7SecS.exe
O23 - Service: Visual Studio Analyzer RPC bridge - Unknown owner - C:\Program Files\Microsoft Visual Studio\Common\Tools\VS-Ent98\Vanalyzr\varpc.exe (file missing)
End of file - 9367 bytes
Thanks...
ashnik is offline
Old 05-06-2007, 06:13 PM   #2 (permalink)
piyush gupta's Avatar
Default Re: Need Help: Plz analyze this Hijackthis log
copy paste you log file here
http://www.hijackthis.de/
press analyze
piyush gupta is offline
Old 05-06-2007, 08:42 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Boot into safe mode and fix these entries:
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-06-2007, 11:45 AM   #4 (permalink)
thanks mate, ne spywares / virii u happen to spot?
ashnik is offline
Old 06-06-2007, 02:53 PM   #5 (permalink)
Microsoft MVP
approx. all are virus/spywares, which I mentioned to fix.
Please review this HijackThis log tuxfan QnA (read only) 7 12-08-2005 12:03 PM
Please chk my HijackThis log file pirates1323 QnA (read only) 2 10-06-2005 10:48 PM
HijackThis isn't hijacking! The Incredible QnA (read only) 11 28-05-2005 12:38 AM
hijackthis analysis johny_4board QnA (read only) 12 22-05-2005 12:12 PM
Please Advice : Go thru my HijackThis Log.. whistler QnA (read only) 5 13-05-2005 09:13 PM
- by chris
