Old 02-06-2007, 07:13 PM   #1 (permalink)
Default help needed on WinRAR problem!!!
when i am trying to extract a winrar file the following message is displayed
"You need to have the following volume to continue extraction:
"Insert a disk with this volume and presss "OK" to try again or press "Cancel" to break extraction"
without having another volumes how can i extract a single rar file!!!...
prinz is offline
Old 02-06-2007, 07:44 PM   #2 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Default Re: help needed on WinRAR problem!!!
open rar file in winrar and select files and folders which u want to extract than drag n drop these files to ur desktop
bhushan05d251 is offline
Old 02-06-2007, 08:34 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
The file seems to be a part of volume based archive...it should have other parts in .r01, .r02 and so on... Put all such files in same folder and then open.
navjotjsingh is offline
Old 02-06-2007, 09:00 PM   #4 (permalink)
without having other parts how can i extract a single part!!!... suppose if i want to extract only .part1... what should i do?!!!
prinz is offline
Old 02-06-2007, 11:39 PM   #5 (permalink)
I am Optimus Prime
Sorry that's not possible. You can open it but it cannot extract the files.
Old 02-06-2007, 11:51 PM   #6 (permalink)
if its a video (.dat) file can i open (view) it in windows media player or any other video players without having other parts?!!!
prinz is offline
Old 03-06-2007, 12:15 AM   #7 (permalink)
I am Optimus Prime
Yeah you can try...VLC media player should be able to play it. Don't expect good quality then in it. Howcome you missed other parts?
Old 04-06-2007, 09:33 AM   #8 (permalink)
without having another parts is it possible to veiw a single in VLC media player?... i have VLC media player 0.8.6. pls tell me how can i veiw it in VLC player without extracting bcz i dont have another parts!!!
prinz is offline
Old 04-06-2007, 09:44 AM   #9 (permalink)
I am Optimus Prime
oops...just realized that video file is in rar file...so you cannot play that file in VLC Media player since you need to extract the file first which you cannot without getting the other parts.
Only option for you is to get other parts and put all such parts in a single folder and then open and extract the archive.
WinRAR Password Problem muthiya2000 Software Q&A 3 21-10-2006 12:12 PM
WinRAR 3.61 qudra Technology News 4 14-09-2006 10:56 PM
Winrar Problem Goldi Software Q&A 2 01-06-2006 08:10 PM
How to do with Winrar ?? saROMan Software Q&A 4 27-04-2005 11:13 AM
- by chris
