Old 30-05-2007, 10:53 PM   #1 (permalink)
Default need help with my pc
hi everyone !
i ve got this prob with my pc. it reboots often . sometimes when i scan my pc,when i try installing big sw,and sometimes without reason. i ve tried changing my os, scanned for virus ,even gone to tye extent of changing my motherboard but in vain. i would be glad if anybody could help me solve this prob....
regards
abinesh
abinesh is offline
Old 30-05-2007, 11:45 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: need help with my pc
may be problem with RAM module or SMPS!! try changng them both
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-05-2007, 12:06 PM   #3 (permalink)
thanks cheeta for replying...i tried changing RAM ... it didnt work another RAM either... the prob persisted..
abinesh is offline
Old 31-05-2007, 07:33 PM   #4 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
dude make it a habit to also include the config of the PC while posting such posts.....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 31-05-2007, 09:09 PM   #5 (permalink)
sure... mine s p4 ht ,512 mb ,ram 915gvwb intel motherboard, and i use xp
abinesh is offline
Old 31-05-2007, 09:13 PM   #6 (permalink)
digit i am thinking's Avatar
what abt smps
digit i am thinking is offline
Old 31-05-2007, 09:18 PM   #7 (permalink)
i haven tried changing that
abinesh is offline
Old 31-05-2007, 09:45 PM   #8 (permalink)
well it is difficult to predict ur problem.One of my friend using 915gav has got same problem but searching so much he found that the prob is RAM module & fluctuating power supply.
check that.
Old 31-05-2007, 10:08 PM   #9 (permalink)
ashfame's Avatar
Are you using a branded UPS?
Sometimes UPS trips and let the PC reboot before it switches to backup mode!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 01-06-2007, 11:59 AM   #10 (permalink)
i m using proview ups.... and "digit i m thinking " i ll check what u say and report sooon .. thanks guys
abinesh is offline
- by chris
