Hello,
I have some movie files that I need to transfer to cds as I do not have enough space on my HDD. It would be better if I convert them to VCDs so I can play them even on my DVD Player.
Can anyone suggest a s/w that can convert
.avi files directly to
.dat ??
Or should I persist with the lengthy process of writing VCDs with Nero ??
Is there any other way that I can write a cd in any format to be able to run on my Sony DVD Player apart from VCDs in .dat format ? (I do not yet have a DVD writer, so unable to write to a DVD.)
Thanks.
