Old 27-05-2007, 10:06 AM   #1 (permalink)
darklord_2007's Avatar
Unhappy directx installation problem
I have directx 9.0b installed on my system.Whenever i try to install 9.0c
the installation overs within a second and says "The installed components are now ready for use".
but when i open the dxdiag it still shows that i have directx9.0b
pls can anyone help me
darklord_2007 is offline
Old 27-05-2007, 10:09 AM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: directx installation problem
^^ Log in safe mode while installing DX. This might help.
cynosure is offline
Old 27-05-2007, 10:14 AM   #3 (permalink)
I tried it already but in vain
Old 28-05-2007, 08:20 PM   #4 (permalink)
uninstall dx 9b thn install dx 9c
abhijangda is offline
Old 28-05-2007, 09:33 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
What os are you using ???
as Install Windows XP SP2 or Windows Server 2003 , they all comes with DX 9.0c integrated... u dont need to install any thing else...
so u must b running any older OS version so install the latest Service Pack, which will make sure autometic installation of DX 9.0c
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-05-2007, 12:05 PM   #6 (permalink)
Smile Re: directx installation problem
yeah its sp2 beta and i unstalled it and installed 9.0c.it worked.
thank you kenshin
DirectX Update: DirectX 9.0c Feb' 2007 available for download Kiran.dks Technology News 6 14-04-2007 10:04 PM
directX 9.0c installation problem reddick Hardware Q&A 5 21-08-2006 07:07 PM
Directx problem rahuljin Hardware Q&A 3 02-06-2006 09:07 AM
problem directx 9.0.c venket_sushant Gamerz 2 06-04-2006 01:32 AM
DirectX problem ApoCalypse Gamerz 9 07-03-2006 06:01 PM
- by chris
