Old 26-05-2007, 01:02 PM   #1 (permalink)
Default Help reg. Formulae In Ms.Excel
Hi guys...
I am bit confused in creating formulae for the following calcullation... Please help me out...
This is regarding share trading:
For Cash Trades : Let us say Trade Amount is 30,000.00
Brokerage = 30000 * 0.75 / 100 = 225.00
If Brokerage is less than 25.00 then 25.00 is charged.
For Margin Trade : Let us say Buy Amount is 30,000.00 & Sell Amount is 31,000.00
Buy Brokerage = 30000 * 0.05 / 100 = 15.00
If Brokerage is less than 15.00 then 15.00 is charged.
Formulae : =IF(AND(D3="Cash"),((C3*E3)*0.75/100),(C3*E3)*0.05/100)
This formulae is till the calculation work... I want this formulai to work for the highlighted statement.
i.e.
in case 1:
If the result is less than 25 then the cell should contain 25.
in case 2:
If the result is less than 15 then the cell should contain 15.
Please help me out regarding this...
Regards,.
navino87 is offline
Old 27-05-2007, 11:12 AM   #2 (permalink)
The Researcher
Default Re: Help reg. Formulae In Ms.Excel
Please try the "IF" statment on the column next to the one containing your formula.
Ramakrishnan is offline
Old 27-05-2007, 11:21 AM   #3 (permalink)
If Cash Trade, Brokerage is Min of 25 and 0.75% amount; else Brokerage is Min of 15 and .05%
IF(D3="Cash",MIN(25,.75/100*D2),MIN(15,.05*D2/100))
where D2 represents the cell where Trade Amount is specified and D3 is the cell which says Cash or Margin...
Arun
sakumar79 is offline
Old 27-05-2007, 06:43 PM   #4 (permalink)
@ Ramakrishnan
Even tried it out... Bt it does't work...
Arun
Thanks a lot man... I hav tried it out, n tis does't seams to work... I am not getting the min value if the amount is less than the min value...
@ sakumar79
Figured out the mistake man... changing the min keywoard with max has worked...
Any way thanks a lot...
navino87 is offline
Old 28-05-2007, 06:01 AM   #5 (permalink)
Oops, sorry about that....
Arun
Help in Excel spp_itim Software Q&A 4 06-02-2007 04:16 PM
Learn Excel from Mr. Excel Ramakrishnan Software Q&A 1 25-12-2006 08:27 PM
help for excel Cool Buddy Software Q&A 2 09-11-2006 04:36 PM
EXCEL hunt Software Q&A 4 01-10-2005 08:04 AM
OCR for formulae Aseem Nasnodkar QnA (read only) 5 09-08-2005 05:11 PM
- by chris
