| Forum |
#1 (permalink) |
There are 10 types of people. Those who understand binary and those who don’t… |
#3 (permalink) |
Rebooting
Adobe® Photoshop® CS3 System requirements
It says 512 MB where as though I have seen CS3 Trial Running with 384 MB ( 256+128 ) MB RAM
rebooting ChotoCheeta.com |
#4 (permalink) |
What the hell! AFAIK, it checks for one gigabyte of RAM and refuses to install if it does not find that. It happened to my friend who has 512 MB of RAM.
Miss me already? See you on Penned Thoughts [http://aayush.me] then. Adios! |
#5 (permalink) | |
Rebooting
#6 (permalink) | |
#7 (permalink) |
Exactly. This is the screen you are supposed to see.
@Choto Cheeta, maybe the trial or whatever installs on any configuration, but you definitely need one gigabyte of RAM to install the full and final version.
#8 (permalink) |
Rebooting
@aryayush
May be, its possible as i saw Trail running... and with Retail version, strange enough because, even Web Site says it should work with 512MB RAM, i have posted the Link too.. do check that out... http://www.adobe.com/products/photos...op/systemreqs/
#9 (permalink) |
Hey those are the reqs for photoshop you said you installed adobe cs3 design premium?
#10 (permalink) |
Rebooting
YEAH, there is info for entire suite rather in Adobe.com every single product in the suite has its own system requirement, and none of it has 1GB requirement !!!
#11 (permalink) |
Yes, and that is because Adobe assumes that if you are buying the entire suite, you are bound to use at least two of the applications at once.
#12 (permalink) |
i got this screen but with only firefox warning.
i closed firefox and installation proceeded without any obstacle. and as i have already said, i installed Design Premium, NOT Web Premium. i suppose web premium makes 1 gb compulsory, but design premium allows me to install without any problem. |
#13 (permalink) |
Well, my friend tried the Design Premium. It didn't work.
OS = XPee. RAM = 512. Dunno what the weirdness is all about.
#14 (permalink) |
Rebooting
@Arya
Most of the time if u dont have Gdedicated GVA memory RAM will be shared with it, may the that;s the problem with ur frnd though he had 512 May b no Dedicated VGA memory !!
#15 (permalink) |
Yeah, that must be the problem. That did not occur to me (though I am no whiz when it comes to hardware stuff so that is hardly a surprise
#17 (permalink) |
Design Premium also requires 1Gb minimum RAM .
http://www.adobe.com/products/creati...gn/systemreqs/
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Adobe Acrobat Installation Trouble | adit_sen | Software Q&A | 13 | 16-04-2007 09:29 PM |
| how to generate premium links from a premium account of rapidshare | arunks | QnA (read only) | 4 | 07-02-2007 11:12 AM |
| Adobe Photoshop 6 installation problem in winXP | Nimtshey | Software Q&A | 2 | 04-12-2005 12:10 AM |
| TUTORIAL: Unattended Installation of Adobe Photoshop | Vishal Gupta | Tutorials | 3 | 04-12-2005 12:08 AM |
| Adobe Premiere Installation Error | talrejaharish | Software Q&A | 5 | 23-09-2004 11:44 PM |
