Old 22-05-2007, 05:00 PM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default Replacement for msconfig
We use "msconfig" command in XP to disable the start up option(i.e, for selective startup
But "msconfig" doesn't work in Win2000 then what should I use.
Plz tell
Kaushal Hiwarkar is offline
Old 22-05-2007, 05:14 PM   #2 (permalink)
Default Re: Replacement for msconfig
You can copy msconfig from XP and use in Win2k...
Arun
sakumar79 is offline
Old 22-05-2007, 05:19 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Plz tell
Or Get it From HERE
Read info in Below Link
rakeshishere is offline
Old 22-05-2007, 05:26 PM   #4 (permalink)
Kiran.dks's Avatar
You have two choices to do it in Windows 2000 viz.
Installing MSCONFIG file in Windows 2000.
1. Download: msconfig.exe
2. Copy it to X:\WINNT\system32 folder of Windows 2000
3. Now it's same as start>Run>msconfig !
OR
Using Startup Control Panel
Startup Control Panel is a nifty control panel applet that allows you to easily configure which programs run when your computer starts. It's simple to use and, like all my programs, it's very small and won't burden your system. A valuable tool for system administrators!
Startup Control Panel is compatible with all modern versions of Windows through Windows XP. Windows Vista, after all these years, finally has a very good startup manager built-in; go to Control Panel > Performance Information and Tools, and then click on Manage Startup Programs on the left.
1. Download and install Startup Control Panel 2.8
2. Manage the startup options.
Utility Source
Enjoy!
Kiran Kumar R
Kiran.dks is offline
Old 22-05-2007, 07:00 PM   #5 (permalink)
If I remember correctly, the Startup Control Panel is also available in AutoPatcher...
But msconfig is more powerful because it includes editing boot options, etc...
Arun
Old 23-05-2007, 08:47 AM   #6 (permalink)
Thank u guys you have solved my problem Thank's
Old 23-05-2007, 05:41 PM   #7 (permalink)
HELP AND SUPPORT
You are welcome
msconfig does not work jayanta2007 Software Q&A 2 14-03-2007 07:28 AM
any way to disable msconfig the.kaushik PC Components / Configurations 1 03-02-2007 10:19 PM
msconfig not working . can anybody help testergt Software Q&A 6 20-11-2005 09:35 AM
MSCONFIG.EXE not opening adorablesrini PC Components / Configurations 11 30-12-2004 09:07 AM
MSCONFIG is not running in Win XP ( Start> Run > Msconfig ) imprince Software Q&A 3 14-12-2004 08:19 PM
