Old 22-05-2007, 08:43 AM   #1 (permalink)
gdatuk's Avatar
Default VLC Media player problems
Hi
I have windows vista home premium
I have all the divx and xvid codecs and Media player 11 installed
I have the latest version of the VLC media player 0.86b installed. But i can never play any type of video clip in it. I can just hear the audio but not the video.
The same clips are playing well in Media player 11. But i want VLC to work for me.
What could be the problem?
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 22-05-2007, 08:51 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: VLC Media player problems
All you actually need to do is to switch to OpenGL Playback.
Do that by going to the Settings Menu > Prefrences. Look at the right bottom of the dialog box that appears and tick the Advanced Options tick-box.
Now just click the plus next to Video. Click on Output Modules under that (Not the plus sign, just the menu item). From the Video Output Module drop down menu, select “OpenGL Video Output“. Thats it, you’re done.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-05-2007, 08:40 PM   #3 (permalink)
gdatuk's Avatar
cool man thanks..that worked
Twitter @cgiridhar
gdatuk is offline
media player u like the most!!! gursimran_2006 Software Q&A 33 24-10-2006 09:47 PM
k50i media problems ... wwwescape Buying Advice 2 23-10-2006 01:46 AM
Can I watch all channels? <<media player or real player>> digidream Software Q&A 2 06-09-2005 04:42 PM
Which is the best media player? bizzare_blue Software Q&A 2 14-12-2004 09:29 PM
Gaming & media player problems rameshld2000 Software Q&A 7 23-10-2004 10:29 AM
