Old 22-05-2007, 12:02 AM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default Compaq presario V3000 problem
I own Compaq presario V3000 . I want to format it through winXP CD. but when ever I boot from bootable XP after loading initial files/drivers it display 3 message:
1) To install XP press Enter
2) To repair press R
3) To quit press F3
But when I press Enter for installation it show following message:
There is no hard disk drives detected
Why it is so ?
Kaushal Hiwarkar is offline
Old 22-05-2007, 12:23 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Compaq presario V3000 problem
That's Because may be u are using a SATA/RAID controller for Which Windows XP doesnt come bundle with Driver's...
To Me, there are 2 way's
For the 1st one you can download the Drivers from here, http://h10025.www1.hp.com/ewfrf/wc/s...1817059&os=228
then put them on a floppy drive
Boot from Installation CD, Put the Floppy in the drive, and Press F6 when Windows Installation ask for a Third Party Hardware driver,
Now select the driver for ur device !!!!
Now the second Method and i think u may not have Floppy in that NoteBook so, here is the option for u, Download the driver, Get ur self WinRAR and then use it to Extract or UnPack Driver in .inf type files, now Download N-Lite to Integrate the Driver in to ur Installation Disk, in that way u will not need a floppy drive !!!
Link = Guide how to use n-lite http://www.nliteos.com/guide/ Note, Follow the Part which says how to Integrate Drivers,
P.S. Windows XP comes with Intel SATA controller driver bundled, u shouldnt have faced the issue in 1st place, wonder why u are facing it... From Where did u get the Windows Installation CD ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-05-2007, 11:21 AM   #3 (permalink)
Thanks I think It will work. I will reply you soon
Old 22-05-2007, 12:10 PM   #4 (permalink)
Rebooting
Originally Posted by Kaushal Hiwarkar
Thanks
WelCome
just to ask, does ur Lappy comes with Floppy Driver ??
rebooting
ChotoCheeta.com
Old 22-05-2007, 05:03 PM   #5 (permalink)
No I will use nlite
Old 22-05-2007, 05:16 PM   #6 (permalink)
Rebooting
OK.. !! Good Luck with it,
rebooting
ChotoCheeta.com
Old 17-03-2010, 11:35 AM   #7 (permalink)
Hi,
I have purchased Compaq Presario V3000 with model no is v3133au ,AMD Turon with Nvedia graphcs card. I used it only for year after that laptop was dead and now no waranty for this. Can I change the mother board with Intel processor and Intel Graphics chipset.
Please let me know if the laptop model supports the intel boards.
Many Thanks,
Rama devi.
Chennai, India
ramadevi1 is offline
WIN XP is not installing in Compaq Pressario V3000 Kaushal Hiwarkar Software Q&A 2 20-05-2007 11:17 PM
Problem with my Laptop (Compaq Presario C500) zegulas Laptops and Netbooks 1 13-03-2007 09:36 PM
Compaq Presario S6010IL Ablenwill QnA (read only) 4 23-10-2005 11:34 PM
