Old 20-05-2007, 10:47 PM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default Sleepy Broadband Idel Broadband
Recently I have taken a Broadband connection of BSNL. Everything is right but there is a problem. When I connect to the Internet It get connected and the speed is also very good. But what happens after 40-50 minutes my connection get hanged. Notification area show that the system is connected to net with the speed of 10mbps but I can't open any web page. I have to restart the connection sometime the whole System. After restart when I connect It gets connected and every thing become allright What will be the Problem.
The second problem is that in the notification area the speed shows 10mbps. why it is so .I think since it is broadband the speed should be much higher. Although It shows 10mbps. The speed is very good. Plz tell me why it is showing the speed so less although it is not.
Kaushal Hiwarkar is offline
Old 20-05-2007, 11:13 PM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: Sleepy Broadband Idel Broadband
You live in India???
Dude 8MBps is the max. speed they provide for the home broadband segment.
And about the notification area... Dont rely on that. Its just a network speed and NOT your internet speed.
More information will be provided by the geeks of this forum.
cynosure is offline
Old 21-05-2007, 09:07 AM   #3 (permalink)
10 mbps is speed from ur pc to modem ie LAN its not ur actual internet speed.
Ravirdv is offline
Old 21-05-2007, 10:51 AM   #4 (permalink)
Mine 2 NIC cards speed is 100 mbps each.
But only the one for LAN gets 100% utilisation cuz the other PC supports duplex 100base connection fully.
And NET gets utilisation less than 1% that shows the maximum speed provided by my ISP and this is what capped it.
Even gettin 2mbps for home plan is not easy talk.
Faun is offline
Old 21-05-2007, 04:11 PM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
First of all are you using parallel telephone connections ?
Second, which interface are you using to connect your modem to PC - USB or Ethernet ?
techtronic is offline
Old 21-05-2007, 04:15 PM   #6 (permalink)
CG Artist
gaurav_indian's Avatar
Broadband in India lol
gaurav_indian is offline
Old 21-05-2007, 04:28 PM   #7 (permalink)
eagle_y2j's Avatar
For ur first problem check your telephone line for electric surge (call BSNL lazy $hits they will do it )
Secondly 10Mbps is speed of data transfer between your Router and USB(virtual lan port) .....check ur connection(broadband) speed here
Registered LINUX USER #438929
eagle_y2j is offline
Old 21-05-2007, 11:48 PM   #8 (permalink)
Thanks u all you have solve my curiosity
Broadband dixit48_v Broadband and DTH 1 08-02-2007 12:59 PM
Is your broadband, really broadband? saiaspire Broadband and DTH 2 03-02-2006 07:59 PM
broadband help shaunak Broadband and DTH 2 15-07-2005 08:57 PM
broadband???? rajeshjsl Broadband and DTH 1 21-01-2005 08:28 PM
- by Anorion
- by Niilesh
