Old 20-05-2007, 08:22 AM   #1 (permalink)
Be The Best
fordac's Avatar
Red face Realtek Driver Update Problem.
Hi am using a FOXCONN 915Pl7AE-8S motherboard and recently i tried to update my on-board Realtek HD AUDIO DRIVER from R1.34 to R1.66. The problem is it worked well for a couple of days and then it doesnt work. The driver says a code 10 error.
I searched the internet and found that a new KB888111 Ver1.0a patch should be installed in order to get it work again but even after installing the new patch also there was no sound....Could someone help me in this???
REALTEK AUDIO CODEC : ALC880
AUDIO CONTROLLER : HD
fordac is offline
Old 20-05-2007, 09:10 AM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Realtek Driver Update Problem.
Download and install this version -> http://drivers.softpedia.com/get/SOU...ver-R167.shtml
Third Eye is offline
Old 20-05-2007, 09:28 AM   #3 (permalink)
Be The Best
fordac's Avatar
Unhappy Re: Realtek Driver Update Problem.
Same Error my friend...Works on first install but when restarted no sound and the device says a CODE 10 Error....
Also when i installed the 888111 Ver1.0a Patch the installation was successful but the update is not listed in my Add/Remove Programs.
Any other way to make it work.
fordac is offline
Old 20-05-2007, 09:34 AM   #4 (permalink)
gooby pls
Third Eye's Avatar
First download Driver Cleaner Pro from -> http://downloads.guru3d.com/download.php?det=745
And clean Realtek drivers from it.
After cleaning,install Realtek drivers
realtek ac 97 driver update? roon294 Software Q&A 5 03-11-2006 12:00 PM
Graphic driver update netkrazy Software Q&A 4 24-11-2005 12:17 PM
Realtek Problem mohit QnA (read only) 5 30-04-2005 02:29 PM
- by Anorion
- by Niilesh
