Old 15-05-2007, 06:38 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Yad
Default Help!! windows\system32\config\system corrupted.
I have a dell 2.6Ghz p4 512mb ram computer with 865 motherboard.
One day when i restarted the machine the computer started showing an error message as follows:
windows can't start
file windows\system32\config\system is missing or corrupted.
i tried to access this file from recovery console but computer shows an error message saying access is denied.
i tried to reach system restore but it also shows access denied.
any help will be appreciated.
Manchester united rocks
Yad is offline
Old 15-05-2007, 08:43 AM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Help!! windows\system32\config\system corrupted.
c http://www.updatexp.com/scannow-sfc.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 15-05-2007, 10:08 AM   #3 (permalink)
thinkdigitreader's Avatar
Exclamation Re: Help!! windows\system32\config\system corrupted.
windows can't start
HI,
R u using admin id & password in Recovery console?
Please go through following process
If you get the error:
Windows could not start because the following files are missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your WindowsXP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
Regards,
ThinkDigitReader
"Knowledge Multiplies By Dividing"
thinkdigitreader is offline
Old 15-05-2007, 09:00 PM   #4 (permalink)
Yad
Originally Posted by thinkdigitreader
HI,
I do not have an administrator password.
it still shows access denied
Yad is offline
Old 15-05-2007, 11:32 PM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Buddy, you definitely need an administrator password to replace the corrupted files.
techtronic is offline
Old 17-05-2007, 10:03 AM   #6 (permalink)
Talking Re: Help!! windows\system32\config\system corrupted.
Hi,
U can use following steps to recover Win XP password.
1. Place your Windows XP CD in your cd-rom and start your computer (it's assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be "Press any key to boot from cd"
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair. It should read something like "If one of the following Windows XP installations is damaged, Setup can try to repair it"
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating "Your computer will reboot in 15 seconds"
9. During the reboot, do not make the mistake of "pressing any key" to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you've made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Regards,
ThinkDigitReader
Old 17-05-2007, 02:28 PM   #7 (permalink)
Section Moderator
gopi_vbboy's Avatar
simple, i use sfc.exe for such purpose
1)Start->Run:Type cmd->Enter
2)type "sfc /scannow"(only the one inside the double qoutes)
3)reboot
if problem persists try "sfc /scanonce"
else format n reinstall
gopi_vbboy is online now
Old 17-05-2007, 10:12 PM   #8 (permalink)
same thing happened to me..
i just ran the repair from xp bootable it si working fine now..
Want cool hosting click here..
http://www.servage.net/?coupon=cust12588
dharmeshhtailor is offline
Old 17-05-2007, 10:32 PM   #9 (permalink)
The Unknown's Avatar
boot frm xp install cd, press enter to start a new install and when it has completed searching for old installs of windows, it will show the current install. press R. install will b repaired.
KDE on ArchLinux
The Unknown is offline
Old 17-05-2007, 11:16 PM   #10 (permalink)
techtronic's Avatar
Hi,
Source ?
Old 17-05-2007, 11:52 PM   #11 (permalink)
gooby pls
Third Eye's Avatar
^Here is the source
http://pubs.logicalexpressions.com/p...cle.asp?ID=305
Third Eye is online now
Old 18-05-2007, 11:42 AM   #12 (permalink)
Originally Posted by techtronic
Source ?
What will u do with the source? Why do u want it?
KDE on ArchLinux
Old 18-05-2007, 12:24 PM   #13 (permalink)
simply follow thinkdigitreader step. If it will detect windows then repair it.
abhijangda is offline
Old 09-08-2008, 12:24 PM   #14 (permalink)
Run Bartpecd & Keep Backup On Other Drive Then Run Ghost Image
vishal687 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/57810-help-windows-system32-config-system-corrupted.html
Quick Help - PC Related - RedCafe.net This thread Refback 29-12-2010 04:11 PM
windows/system 32/ config/system files corrupted or missing ? mkmkmk Software Q&A 9 02-04-2009 02:55 PM
System.ini corrupted - windows xp not loading SGS_001 Software Q&A 14 24-02-2007 07:23 PM
getting system error in system32 rajesh_verma Software Q&A 1 11-03-2006 08:03 PM
No System32 directory in my Windows Folder ..? aag692k Software Q&A 13 27-10-2005 12:15 AM
Windows not start -windows root\system32\hal.dll missing Aanand Software Q&A 1 16-09-2005 06:40 AM
- by Anorion
- by Niilesh
