Old 10-05-2007, 11:59 AM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Unhappy HELP.Problem , again !!(Windows XP)
I cant boot into windows XP . it is giving this error . it didn't solved my problem . coz my win xp cd is corrupt .
i cant even repair my windows xp installation .(damn)
HELP
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 10-05-2007, 02:42 PM   #2 (permalink)
digital2006's Avatar
Red face Re: HELP.Problem , again !!(Windows XP)
you can boot in linux by live cd .
replacing ntoskrnl,explorer,& other sys files from another computer is not recommended s it may further aggravate the problem
BTW is your windows under warranty? or it is **rated
if its**rated or illegal copy, then i cannot help u.
if its a legal one you may get a replacement 4 corrupt cd
PENTIUM D 820\GIGABYTE 945GZME\1GB RAM(533)\160GB SATA II HDD\SONY DVDRW DRU-820 A\THINKING OF BUYING A G CARD
digital2006 is offline
Windows XP problem crystalboi Software Q&A 5 22-04-2007 10:06 PM
Windows Xp x64 Problem max_demon Software Q&A 6 18-12-2006 09:23 AM
Linux AV problem or windows AV problem?? thilina Open Source 2 02-09-2006 09:27 PM
Problem with Windows XP mkpaul Software Q&A 3 22-05-2006 01:03 PM
windows 2000 and windows 98 problem swap_101982 Software Q&A 4 30-04-2005 12:04 AM
- by Anorion
- by Niilesh
- by chris
