07-05-2007, 11:28 PM
Dual-Boot makes system slow?
I have often heard that keeping a system in dual-boot makes it run slow. Plz tell me whether this is true or not? If yes then why?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
08-05-2007, 01:32 AM
I am Optimus Prime
Re: Dual-Boot makes system slow?
It mainly depends on the system rather than blaming dual boot configuration. Mostly not much speed difference is noted since you are loading only 1 OS at a time. People have said that it made their systems slow but only blame in those cases is system not being powerful enough.
08-05-2007, 02:34 AM
18 Till I Die............
Ask them to explain how does that happen?
http://www.bash.org/?258908
08-05-2007, 03:07 AM
String Phreak
I don't see how dual booting can make any system work slower. It only increases ur startup time.
08-05-2007, 03:12 AM
Microsoft MVP
most ppl think that if they'll install more OS in their system, there will be more data on the hard disk (which is usually one in most of the system).
Thats why they are afraid of the performance decrement. But thats not true.
Dual boot never slow down any system coz u run one OS at a time.  (and don't say about vmware or virtual pc  )
08-05-2007, 06:54 AM
Host4Cheap.org
EGGJACTLY.
Why would dual boot reduce performance. Same thing as one OS, just that two OS on different partitions.
Human Tendency to blame someone else
http://www.host4cheap.org/
08-05-2007, 07:32 AM
But It has made my comp slow.
It is now taking more time to boot.
----------> http://www.blogofwebmasters.com/ <---------
WEBMASTERING TUTORIALS, ARTICLES AND MUCH MORE
08-05-2007, 07:44 AM
Host4Cheap.org
Reduce the Default 30 second Timeout to 2 sec and your BOOT Process will be fast LMAO
08-05-2007, 07:46 AM
1337 |)00|) \m/
Yeah, boot-time will increase. But once loaded, an OS won't be slow, unless you are not using any virtualisation technology.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
lol...
how to do that?
08-05-2007, 07:49 AM
1337 |)00|) \m/
Not necessarily. A boot loader takes time to read the MBR. So, even if that delay is reduced, the boot time will be longer than that of a single boot.
If you're on GNU/Linux, edit GRUB.conf in /boot/ and reduce the timeout delay from there.
Reason: Automerged Doublepost
08-05-2007, 07:57 AM
Host4Cheap.org
LOL, someone lacks on Funny bone  no offence
MBR is only a few bytes bro, dont expect ages to read MBR
08-05-2007, 09:50 AM
left this forum longback
I think GRUB bootloader for GNU/Linux etc will be having a default 30 sec delay to choose which OS u want to run.just select the OS of ur choice and run.that's it.nothing to blame.just look carefully at GRUB screen.
or u can even hide grub to boot directly a os(need to edit /boot/grub/menu.list and add hiddenmenu and select a default os by number).
08-05-2007, 10:15 AM
The Devil's Advocate
yeah it makes the booting slow ... i agree ... i take a lot of time to decide which OS to boot into
http://beingmanan.com
08-05-2007, 10:17 AM
Host4Cheap.org
I use XOSL as my boot loader. Simple, fast and easy
http://www.ranish.com/part/xosl.htm
08-05-2007, 01:07 PM
But why will the boot time increase (without considering the time to choose the os)?
www.techani.com
08-05-2007, 01:31 PM
If you don't consider the time of choosing the OS, then boot time doesn't increase. It remains the same. It's only upto selecting which OS to boot that extra time is taken.
08-05-2007, 02:13 PM
TechTin.com
No use of any third party software to configure boot system.Just follow this:
Start--> right click my computer--> properties-->Advance-->startup and recovery-->setting.
Now configure as per ur choise.
08-05-2007, 02:23 PM
#19 (permalink)
Dreamweaver
nope
08-05-2007, 07:13 PM
#20 (permalink)
Fresh Stock Since 2005
I agree... Thats just a myth...
http://www.khattam.info
08-05-2007, 07:46 PM
#21 (permalink)
Tell me how to reduce it I am Using WinXP and Vista
08-05-2007, 09:08 PM
#22 (permalink)
Microsoft MVP
There will be 2 boot loaders: one of Vista and one of XP.
U'll hv to decrease time-outs of both boot-loaders. So just do following in both OS:
Open "sysdm.cpl" and goto "Advanced" tab and click on "Settings" button in "Startup and Recovery" section. Now u can decrease the time of "Time to display list of operating systems".
U can also do the same by using "msconfig".
08-05-2007, 09:49 PM
#23 (permalink)
Thanks Vishal you are always helpfull
08-05-2007, 10:18 PM
#24 (permalink)
Microsoft MVP
^^ u r welcome buddy.
09-05-2007, 09:40 AM
#25 (permalink)
Does this thread hacked by dual boot reduce time
i think it start off with a dsicussion on
"Will Dual Boot makes system slower?
No offence guyzzzz
09-05-2007, 09:46 AM
#26 (permalink)
^^ whats ur point
